ok i had the tyre balanced they were all off quiet abit, i also had the wishbone bush replaced, and had the tracking checked but it was spot on, the drive is much much better but still at times is still little twitchy, at high speeds it dont twitch at all now but its more like when i sometimes brake hard or it i go over some potholes, as i say its not as bad as before but i like to get it sorted out, any more advise?? the only thing i could think of is the tyres that i swaped around, the front were worn so i did swap the rears which had alot of tread, to the front, you think that could be the cause?, or tyre pressure? before i was running 36 front 34 rear, now i changed it to 32 front 30 rear, that has improved the problem a little,and also changed the rear discs and pads and front brakepads, but like i said the problem is still there a little, any tips??
