Sky InsuranceBadger5
Results 1 to 11 of 11
    Aug 2008
    37
    Cruise control retrofit.......Sorted!
    Ok here is the deal...... I have fitted the stalk on my 2006 TDI, and coded the steering wheel ECU (MFSW) to include cruise. Measuring blocks relating to Cruise stalk were also checked for correct functionand all OK, BUT...... NO banana.... it does not work?????
    As for the wiring, I was pleasantly surprised that the wire (black/white) was already in place in the steering Connector plug and ASSUMED it ran all the way to the ECU.
    So, my question is.... Anyone with this experience confirm that the wire does indeed go all the way to the ECU as shown in the wiring diagram or is there an intermediate connector somewhere?
    Is there anything else that has to be coded with VAGCOM other than Steering ECU? Any other reason you can think of?
    Stevie C
    Mar 2008
    Bristol
    153
    Give Mattandrew a shout, he helped out with mine although we did not have any problems... there is a small wire that needs to go up to and near the wiper motor but cant remember what its for!
    Audi A3 2.0 TDI Dolphin Grey |Loads of extras... & Mods...
    Mods Fitted - Full Rieger Infinity Body Kit including Splitter | De Chromed Front Grills | Graphite RS4 19" Alloys |MK5 Golf GTI Brakes |S6 DRLs | Jetex Twin Tailpipe Exhaust | Revo Remap | TT FBMFSW |S3 Retro Pedals | S3 Air Vents | Diamond Front Component Speakers | Custom Parcel Shelf |Private Plate
    Mods to be done - R32/R line Gear Knob | Interior Map lights |35% tints
    Stevie C
    Mar 2008
    Bristol
    153
    PS Matt has done the fit on the steering ECU too
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    Have you got the right version steering wheel ECU?
    If the wire is present in the plug there is no need to run any more
    I had issues with mine then realised I hadent told the car I had fitted cruise. You have to log into the engine module in VAGCOM
    log in to engine 01
    select Coding II - 11
    enter 11463 in to the coding
    this may help coding etc if you havent already got
    http://wiki.ross-tech.com/index.php/...ial_Procedures
    If you need to buy a new electronics unit, make sure that you buy one that is compatible with your steering wheel slip ring. I spent quite a few hours trying to figure out why my new module didn't work properly, until it was found that it wasn't compatible..
    As far as I know, there are two different slip rings:
    1K0 959 653 A
    1K0 959 653 D
    If your steering wheel module (use vag-com to check) is 1K0 959 549 E or F, then you have the D slip ring. If the module is 1K0 959 549 or 1K0 959 549 A, then you have the A slip ring.
    The correct replacement modules with cruise functionality are:
    8P0 953 549 A (compatible with slip ring 1K0 959 653 A)
    8P0 953 549 C, D or F (compatible with slip ring 1K0 959 653 D)
    Hope this helps.
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    Aug 2008
    37
    Well........ The steering wheel ECU is an "F" model so should be compatable. Just also tried the engine ECU coding as suggested but its still dead. There are also no VAGCOM errors listed anywhere on the car
    27,099
    Yeah F basically does everything anyway, I just reinstalled vista so elsawin not up yet so cant check the schematics for yer, but given the F version I assume its a facelift 05 onwards model so when I check elsa I know what year.
    Dec 2006
    Ireland
    2,538
    これで、ここでは、少数の歴史と語ったが必要だ 無名の英雄 この土が削除されます ある人は、継承はされています 造幣局からの輸入 人々の多くがないのにネウルエウンイ 事実、この老いたहेごみमेरे 彼は帽子にゴミ収集した これは、うわっイレオルスがズボンです そして彼は、フラットに住んで協議会
    彼は'真のनानाである 大きな皿の後に起動チクヒギル 彼はउन्हें得ることができる職業を持って 彼は根が何उन्हेंデイジー電話
    mattandrew's Avatar
    Sep 2007
    971
    As marc says have you tested
    Is the wire definaely in the plug? It only had to run it from the back of the steering wheel ECU to the top of the engine bay, it was present the rest of the way
    might be worth trying the engine coding again just to make sure its accepted
    sorry cant be of any more help
    Previous
    S
    Ibis White - 2007
    Current
    S3 Black - 2001
    VCDS user
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    You can check the MBV's in engine 01 to see if the functions of the CC stalk are working.
    I've erm fitted one or two CC's in my time and if the black/white is present at the steering controller it has always been fully wired to the ECU.
    Have you used the 11463 login as above?
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    Aug 2008
    37
    Sorted!
    Well guys, thanks for all your help. Its finally working!
    To be honest I still dont know where the problem was, all I did was recode the steering module back to the old code and then to the new one again (0002042) then do the engine ECU login 11463 again.
    Its great thought to see others taking time on this forum to help others.
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Probably the login then.
    Stu.
