Volks AutosChris Nott
Results 1 to 12 of 12
    Apr 2008
    98
    VAG-COM in South Yorkshire ?
    Just had BOSE removed and had aftermarket kit fitted but now need GALA en-ableing via vag-com.
    Anyone in the area that could do a good deed for some beer or cash ?
    Will be posting pics of new install inc my custom made sub box c/w JL 8" sub behind original trim.
    If anyone can help please contact me.
    Cheers Matt
    The Damned
    Apr 2007
    South Yorkshire
    344
    PM sent
    Dec 2006
    Ireland
    2,538
    what head unit do you have? you can enable GALA from the system menu on most Audi head units.
    Apr 2008
    98
    Have RNS-E which did have BOSE + audio pilot thus no option for GALA in menu.
    The RNS-E needs re-coding for GALA
    JohnS3's Avatar
    Oct 2004
    3,021
    You might want to experiment with removing the Bose wire so you don't get the Bose EQ settings. Although I'm unsure if the EQ is done in the RNSe or the now removed Bose amp. Does anyone know for sure?
    Apr 2008
    98
    Yes I need to disconnect the BOSE wire, some views are that it alters the EQ from the RNS-E and en-ables the internal amp (not used in my install) others say that the EQ can only be altered through coding.
    Either way I need to en able GALA as was done through BOSE audio pilot which is now removed.
    Will update you when I find out
    Apr 2008
    98
    Just disconnected the BOSE wire and can confirm it sounds miles better , both Bass and treble control on the RNS-E work !
    Disconnect BOSE wire = Better sound , better EQ
    Apr 2008
    98
    Sorted now, big thanks to Von Maximo !
    Thanks again
    The Damned
    Apr 2007
    South Yorkshire
    344
    Quote Originally Posted by Whiteatom View Post
    Thanks again
    My pleasure mate, Anytime you want it doing again you know where I am!
    Kontraband's Avatar
    Dec 2007
    1,998
    Where ARE you??
    Apr 2008
    98
    Rotherham, Van Maximo may need you quicker than you think, just tried reversing tonight and does not recognise reversing sensors now !
    Will give u a bell
    Kontraband's Avatar
    Dec 2007
    1,998
    Ahhh Roth Vegas...
    Both of you?
