Sky InsuranceAH Fabrications
Results 1 to 21 of 21
Thread: RNS-E & VAGcom
    Kris's Avatar
    Sep 2007
    Nottingham
    220
    RNS-E & VAGcom
    Just fitted an RNS-E in my 07 S3, after reading all the retrofit posts i couldn't beleive how easy it was. All of 10 minutes to pull my Concert unit out and plug in the RNS-E with no adaptors required and later in the day another 20 minutes to pull the glove box and mount the sat receiver. All is working well but if anyone can help with VAGcom as i beleive it may throw up faults if not coded? and i also want the S3 start up screen. I live in Nott's but any excuse for a drive is good within reason. The obligotory beer tokens will be offered.
    Can anyone help ...... pleeeease.
    Kris
    RS Focus MP 350
    Porsche 997 Carrera
    S3 Sprint blue
    A3 SLine170TDI
    Dec 2006
    Ireland
    2,538
    Check this post out for the coding details: http://www.navplus.us/forums/showthread.php?t=62
    Kontraband's Avatar
    Dec 2007
    1,998
    oh yeah, that reminds me... I need to get my splash screen sorted too...
    good effort... its a breeze innit.
    L60N
    s3 splash screen ownz0rZ
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    i am more than willing to help with any vag com issues but i am a bit far from you..........
    Kris's Avatar
    Sep 2007
    Nottingham
    220
    Appreciate the offer, if no one closer steps up i may take you up on it. Less than a 2 hour drive depending on where in Cheshire you are. I've got sat nav and the S3 does 50 plus mpg on a run (not)
    RS Focus MP 350
    Porsche 997 Carrera
    S3 Sprint blue
    A3 SLine170TDI
    Feb 2004
    79
    Your car shouldn't be showing any errors, because of RNS-e install, except for a 'ZF Output' error.
    This is because of the different aerial system used in the RNS-e. This cannot be cleared with VagCom, it needs a new converter-box-thingy. JohnS3 has posted a great thread about the fix, it costs about 150.
    This is only a minor fault though, and as long as you have decent radio reception most people leave the fault on. Unless the dealer specifically scans the radio module they will not even pick it up.
    I am in leicestershire, so if you want your splash screen coding or some other tweaks I would be more than happy to help you out.
    Khufu's Avatar
    West coast of Scotland
    5,693
    i take it it will work without any codeing, allbeit not 100%? Im bidding (well, im outbidded at the moment lol) on one on ebay at the moment but dont have a vagcom lead, only an OBDII canbus one. Hope Im not bidding against anybody here...
    Feb 2004
    79
    Quote Originally Posted by Khufu View Post
    Dependant upon your car it should work fine without any coding, but you may have to code the DIS to work.
    I see that your car is 2003, does it have double din dash or single?
    Oct 2006
    67
    Don't you also need to check through VAG.COM that the wheel sizes are coded correctly? I'm sure I had to adjust mine when I retro-fitted my RNS-E. I understood that RNS-E untilises the ABS sensors to supplement the satellite data or when satellite is not available (eg heavily built up areas, tunnels etc).
    I'm in Peterborough and have VAG.COM. Not used it in a while, so my knowledge might be a little rusty , but the offer's there.
    Gary
    Audi A3 Sportback Ibis White TDI170 S-Line - RNS-E - BOSE - Leather - Xenons - Auto Lights and Wipers - Interior Light Pack - Parking Sensors
    Khufu's Avatar
    5,693
    Quote Originally Posted by spencerjoel View Post
    single din at the moment, will need to get the rest of the switches/cage etc too!
    Kris's Avatar
    Sep 2007
    Nottingham
    220
    If it's only the ZF thing (whatever that is), for 150 i'd leave it as it is.
    Would really appreciate it if you could set up the S3 splash screen. Can you PM me as to when would be convenient to you and obviously contact details.
    Mucho thanks.
    RS Focus MP 350
    Porsche 997 Carrera
    S3 Sprint blue
    A3 SLine170TDI
    JohnS3's Avatar
    Oct 2004
    3,021
    If you have access to vagcom you should code the instrument cluster to let it know navigation is fitted. The RNSe needs to be coded to suit the options fitted to your car (not the car it came out of) such as tyre diameter, bose, MFSW, phone prep, aux input, LHD/RHD (so the voice comes from the correct side) & startup screen. A full list of codes can be found here
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by MarcQuinlivan View Post
    Quote Originally Posted by JohnS3 View Post
    It's like deja vu all over again.....
    JohnS3's Avatar
    Oct 2004
    3,021
    Missed that one....... Sorry!
    Khufu's Avatar
    5,693
    maybe not, it seems to have vanished off of ebay altogether...
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,473
    Quote Originally Posted by galewis View Post
    No, the RNS-E auto calibrates over the first 500 miles or so.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    Whats this S3 splash screen ur going on about?
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,721
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    Ah, ok so it's a motion visual when you startup.... And needs to be enabled. Got ya, wasn't sure.
    Kris's Avatar
    Sep 2007
    Nottingham
    220
    Thanks for sorting the VagCom, really is so much easier listening to voice guidence from the right hand speaker
    Also thanks for the offer of help and info
    RS Focus MP 350
    Porsche 997 Carrera
    S3 Sprint blue
    A3 SLine170TDI
