I'm sure it is, I didn't say it wasn't either.
All my previous manual cars have been absolutely normal and a pleasure to use
all have also suffered to a lesser or greater extend of driveline shunt, its a simple fact, unless you slip the clutch to the point of burning, or drive a race car with no transmission slack each time you move off, you will have an uptake of all of the parts in the transmission, the gears in the gearbox, the UJ's, the driveshafts, even the engine moving on its mounts, all play a part. same goes for when you decelerate, all these parts release their inertia, and if you don't "mask" them to some degree you get whats called driveline shunt.
I guess Bowfers point is that in a DSG, unless you're in D, it takes more effort to mask this than in a manual, where you depress the clutch. which is totally fair and accurate, however saying that manual cars do not suffer from shunt simply isnt.
next time you're coming up to a set of lights, take your right foot off the throttle and do absolutely nothing with your left foot, leave it on the foot rest, don't use it! you will experience some driveline shunt.
I love manuals, don't get me wrong, I do. however I drive 80 miles a day, on the A1 The part between letchworth and Hatfield is pretty pants, much of it in stop start traffic. 40 miles shouldnt take an hour and a quarter!
When I take the wifes car to work, using my left foot all the time seems particularly pointless and old fashioned.
I hated "normal" auto's, the way the engine note/revs never matched the engine speed actually made me feel sick (Honestly)
DSG seems to be a really good compromise to me, I get control of what gear I'm in (To some extent - the change up at max RPM annoys the living sh!t out of me) and the engine note matches the speed
Criticisms - the "learning" is pointless, as too is S mode, no idea what that's for, and the change up at max RPM is annoying, especially if you're trying to time it right (What's wrong with but bouncing off of a rev limiter!)
that's it from my side though
