1. Update the phone to the latest software - Connect your Nokia E65 to your pc using the usb-cable and update its software to the latest version, use Nokia PC Suite "Update phone software" and follow the instructions.
2. Download Nokia 810 Contact Download Application for Nokia S60 3rd edition devices - http://europe.nokia.com/A4143881
3. Use Nokia PC Suite "Install applications" and install the .SIS application on your phone.
4. Delete the paired device to your car in your bluetooth setup on the phone if you have one.
5. Go to your car with the phone and turn on the ignition and start the Nokia Contact download application - Menu - Installat. - Download, answer Yes and confirm every question, and then your contact list is downloaded to the car
6. Finished - you can now see your contacts in the DIS, and you can use the MFSW to control and select person you want to call.
