In a thread that sees Dave and Bowfer getting on (Finally kissed and made up - I knew there was some underlying frustration there chaps, glad you finally got on top of it all) I feel compelled to hop in too
Much has been said about the two things that make HID lamps legal and as I have retro fitted Xenons to my wife's car and have factory fit Xenons on my A3 I thought I'd give you my thoughts
Height adjustment
I've adjusted the lights on the wife's car to pitch down slightly more than normal to take into account the extra brightness, obviously when you realise that Xenons are merely brighter, whiter bulbs its clear the effects on your beam pattern are minimal, the adjustments were just to ensure they still met with the original headlamp height (Which was always a little high)
result - little glare to others, none more than standard ones and as for over 90% of the time she travels alone or with me there is no impact to extra loads, obviously when we do carry very heavy loads we use the rather neat and VERY clever manual headlamp adjustor that's just to the right of the headlamp switch to knock them down a notch or two
As we don't glare other roadusers, so obviously not all retro fitters are "I'm alright Jack" - a very sweeping statement Dave!
A3 - sits there every morning, levels itself to my downward sloping driveway and never resets, As the clever folk at Audi call them self levelling I unfortunately do not have any luxuries along the lines of a manual adjustment switch so I have to turn the lights off on the road and back on again to get them set right, way clever eh! Audi don't seem to think this is a problem but then obviously its me being a moron.
Headlamp washers
Wife's car - once or twice a week clean them with a cloth, as I do the indicators and rear lights, takes only a couple of seconds and makes things safe. I think the law states that your lights and numbeplates need to be clean to be roadlegal don't they?
A3 - headlamp washers somehow miss the indicators and rear lights for some obviously obscure design fault so I have to repeat the above excercise to remain road legal (Unlike 90% of the daring people I see everyday on the A1 who clearly think their "HID equipped with headlamp washers" cars effectively clean themselves when they wash the headlamps)
Oh, BTW the headlamp washers on the A3 are particularly pathetic, if you use them, then go out with a cloth, you'll see it actually removed feck all dirt
Also, looking into other "uprated" halogen bulbs, if you read into this deeper you'll see the legality of them are also suspect, however clearly this doesnt bother Dave as you regularly used them on your previous Audi's
Personally I didn't have any snobbery when it came to standard or retro fit, I used standard when it was available and retro fit when the option was not offered by the main dealer, the difference is minimal when installed correctly and sensibly so please be aware of this when making comments
for reference I have 2 LG LCD's and a Sony, are they worse than Panasonics?
