Badger5Chris Nott
Page 3 of 3 FirstFirst 123
Results 81 to 115 of 115
  1. #81
    JohnS3's Avatar
    Oct 2004
    3,021
    Mmmm, inbuilt DRLs on the new A3 cab..... Expensive me thinks!!
  3. #82
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by JohnS3
    hmmm... so should we hold off and try to acquire these instead of the S6 ones?
  4. #83
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Me thinks!
    Depends if they are a exact fit or not....bumper or bonnet or both may be different shape than ours.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
  5. #84
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by JamS3
    Me thinks!
    I was thinking the same thing, plus I would assume they are part of the xenon package.
  6. #85
    JohnS3's Avatar
    Oct 2004
    3,021
    They look like Xenons in the picture. However this may be very expensive, Kufatec are selling a Bi-Xenon kit for almost 1400 Euro. Imagine what a dealer might ask for them? Make the S6 LED strips look like a bargain!
  7. #86
    Nov 2007
    20
    Smile More Info
    Heres a few websites if any1 needs more info about these lights. and theres plenty of pics aswell.
    http://www.motor-talk.de/forum/s6-le...-t1332549.html
    http://www.faudiq.de/anleitungen/Exterieur/S6%20tfl.htm
    hope this helps
  8. #87
    Sep 2006
    Surrey
    1,224
    Ooo the LEDs are ABOVE the headlight (eyebrow style) rather than underneath. Interesting positioning. Ehh confused on which to get heh.
    Hey wasn't somebody getting them done here? Where's the progress...
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
  9. #88
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Hehe. Just spent the day installing my LED driving lights and I'm really pleased with the result.
    Bought 20 individual LEDs for 5.90 via eBay and fitted them to the foglight grill.
    I've attached some piccies of the job, but it was going dark when I finished, so you'll have to wait until tomorrow for a full daylight picture of the finished job....
    By the way - has anyone got real original LED running lights? Do they turn off at night when you switch the lights on to avoid dazzle or do they simply stay on all the time the ignition is turned on regardless of the main lighting switch position?
    For those who may want to know, these are the LEDs I bought...
    http://cgi.ebay.co.uk/NEW-20PCS-12V-...QQcmdZViewItem
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
  10. #89
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by alfiejts
    That's a not bad solution.
    These would've been better maybe:http://www.maplin.co.uk/Module.aspx?...47376&doy=1m12
    They can be cut into 100mm strips.
    Also you can find ultrabright 10mm LEDs and holders on there too
    8P2 S3
  11. #90
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Yes I had seen those strips. I considered trying to put them inside the headlights.
    For fitting into the foglight grill, the separate LEDs are more straightforward than the strips, unles you intent to stick the strip on the front which would spoil the effect.
    I also gave a lot of thought to the size and brightness of the LEDs.
    There are 3mm, 5mm, 8mm and 10mm available. I tried to judge it. Bigger LEDs aren't necessarily any brighter and you wouldn't get as many in the same fixed length of the grill, so you'd get the impression of a smaller number of individual LEDs rather than the "line of light" you can get with more smaller LEDs in the same space.
    We'll have to wait until daylight to see the effect with these, but at the moment, judging them at dusk and at night, I'm really pleased with the result with the 5mm 30,000mcd brightness LEDs with 60 degree beam....
  12. #91
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Here are a couple of daylight photos.
    Looking good to me for 5.90.....
  13. #92
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I'm not sure they really are 30cds! The most powerful LEDs from maplins were only about 2 cds. Bit of a difference. And I know the "superbrights" are as bright as the ones above as I have ordered some before.
    They're certainly bright enough though. I think you need more though IMHO.
    8P2 S3
  14. #93
    buffalino's Avatar
    LIVING THE GOOD LIFE
    May 2007
    barcelona
    75
    a bit 2 bright
    i think
  15. #94
    Sep 2006
    Surrey
    1,224
    Looks good but a little short. Add some more so it goes across the whole plastic
  16. #95
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    Iv just won a decent set from ebay about 35 inc postage. when iv installed them ill take some pics for u guys! ill be using them as fog replacements rather than day lights as they will look like christmas lights on constantly lol.
    Fez ----Audi A3 SE 2.0TDi --- MOBILE OFFICE ---
  17. #96
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    I think these look better in the headlights, anyone tried that with the A3?
  18. #97
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Its hard to judge the brightness in photos, as the auto exposure doesn't paint a true picture.
    In reality, they look about as bright as genuine LED DRLs - they're bright enough to make a diffference in daylight, as they should, but they don't dazzle at night - yes they look bright at night, but only in the same way as that the dipped headlight looks bright, when you look at it...
    The problem with fitting them all the way across the grill is that there's a gap where the upper fastening clip goes - but you're right, a longer line might look better, so I'm going to order some more and try and fabricate something to bridge the gap in the plastic..
  19. #98
    Naresh's Avatar
    Essex
    260
    Hi there, neat mod! Have you got some kind of waterproof connector on the end of the LED's to allow easy removal of the grills, and did you wire up directly to the sidelights?
    There are also waterproof LED flexible strips available that could be fitted across, say the middle or bottom grill section, and can be cut to suit as well. See here:
    http://www.ultraleds.co.uk/water-pro...te-p-1037.html
    I installed them recently on my TT:
  20. #99
    JohnS3's Avatar
    Oct 2004
    3,021
    Another shot of the A3 cab DRL.
  21. #100
    fesss_84's Avatar
    Sylar
    Nov 2007
    Middlesbrugh, UK
    165
    while we are talking about lights, iv recently changed my bulbs to xenons (Phillips) 80& more light supposedly, but when iv installed them, the light doesnt look even, how do i fix this?????
  22. #101
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    What are the chances that the cab bumper plus lights would be a direct fit to a facelift 8P??
    8P2 S3
  23. #102
    The Damned
    Apr 2007
    South Yorkshire
    344
    Quote Originally Posted by staz1000
    Judging on past history with face lifts (2004) chances are it could also mean a new bonnet?
    Oh and sorry chaps for not coming back with pics of my a6 led light retro fit. A change of plan has stopped me from finishing of the grills and taking pics. But they're installed, working fine and look the absolute dogs!
    Even though it cost way more than the cheaper alternatives shown on this thread and a lot harder installation I'm more than happy with the result and would definetly recomend going down this route, no offence guys who have done the cheaper route, but in my opinion the A6 way looks more of a factory fit option and more substantial than a DIY one that will sure be copied the chav's natiowide
  24. #103
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Naresh,
    To answer your query, I connected them to a spare "ignition feed" connection in the under-bonnet fuse box, so they're on all the time the ignition is on, regardless of the light-switch position, just like the real DRLs.
    I used a "spade" connector to plug into the top of one of the spare fuse supply points on the fuse box and a 4 amp inline fuse in the supply wire. Had to make a small hole in the side of the fusebox to feed the supply wire out through and then dropped it down behind the bumper.
    I used those little "screw connector blocks" to connect all the LED wires together and to connect them to the supply wire, so I could easily disconnect that if I had to.
    I did think about buying those strips, but thought they would stand out stuck on top of the grill and it was no hassle to drill the grill and fit the others from behind. I thought that way, fitted from behind, they'd get less weather abuse than a strip fitted to the front.
    Just ordered a second set of 20 to try and fill the gap to the end of the grill - another 4 each side should do it.
    Also got some red ones to fit into the footwells and the overhead panel and to link to the instrument lighting....
  25. #104
    JohnS3's Avatar
    Oct 2004
    3,021
    Naresh,
    DRL equiped Audis have a switch next to the lighting controls to turn them on or off.
  26. #105
    Dec 2006
    Ireland
    2,538
    My car doesn't have the DRL switch, but I was able to use VAGCOM to enable the scandinavian DRLs. My dipped headlights now come on with the ingintion - this can also be changed to use the foglights instead of the main beams.
  27. #106
    S3IZZO
    Quote Originally Posted by Teejay
    why did you fit 19 inch RS4 replicas then? they don't make any improvements to the actual workings of the car.
    I didn't, they were on the car when I bought it - I'm changing them for Work Meister S1 3 peice wheels - they have forged centres and are extremely light (as well as being good looking) reducing the unsprung weight of the wheels thus giving some improvement in performance
  28. #107
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by MarcQuinlivan
    Ahh, didn't think of that. I also enabled the Scandanavian DRLs too (if anyone wants to know, they are front and rear DRLs. As opposed to North American which are front only)
  29. #108
    Nov 2007
    29
    DRlights
    Count me in too!!
    2006 A3 SPORTBACK 170TDI QUATTRO S-LINE MISANO RED ,XENONS, LIGHT AND RAIN PACK, INTERIOR LIGHT PACK,MFSW WHEEL, ARMRESTS , I-POD, BLAH BLAH!
  30. #109
    giblets46's Avatar
    Nov 2006
    156
    Any update on anyones project here? Quite tempted after seeing Naresh's TT rather then the thicker single lights, though close up I thought the lights went all the way round the plate (due to reflections)!
    Any spelling/ grammatical errors are there purely to annoy!
    A4 2.0TDI (143) S-Line Quartz Grey
  31. #110
    Naresh's Avatar
    Essex
    260
    Guys, I should be doing an A3 install fairly soon so you can see the results. If anyone is interested in these feel free to drop me a PM.
  32. #111
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by Naresh View Post
    Wouldn't mind seeing the pics and install guide. Think I might have a few quid to spare after my recent mods!
  33. #112
    Naresh's Avatar
    Essex
    260
    Thanks. Have a look Here for some more of my interior LED mods. Enjoy!
  34. #113
    Dec 2006
    Ireland
    2,538
    Thanks. I'll check them out later.
    Just had a quick look at the start button one. Do you have any details on how you wired the button into the system?
    I just purchased the RS4 start button and want to fit it into the ignition system, but am unsure about which wires to tap into. Any help greatly appreciated.
  35. #114
    Naresh's Avatar
    Essex
    260
    Hi mate have you got any pics of the RS4 start button and where in the car are you planning on fitting it?
  36. #115
    Dec 2006
    Ireland
    2,538
    See more in this post.
    It just slots into the gap next to the handbrake (well, you need to remove the centre console and connect it in from underneath as it is wider at the bottom than the top.
    There is a square 8 pin connector underneath, but the dealer has been unable to figure out the required part.
    Here's are two photos from a german dude's DIY site, but he doesn't post any notes on the install. (www.faudiq.de). I also have the Nokia 610 Car Kit, so will be mounting the control knob thingy in the same place.
