EM TuningAH Fabrications
Results 1 to 17 of 17
    Boydie
    Dual Climate Control
    Right im in work and cant be assed going to the car so going to ask you lot
    the other week i did something funny with the climate control
    twiddled the knobs a bit and i found that both sides would be the same temperature if only using the drivers side knob
    my neighbour turned his side up cos he couldnt hack the 16 degree heat and now my settings are messed up
    how do i do what i did before?? lol
    i mean, how do i set the climate control so i can adjust both sides with just the drivers side knob?
    thanks
    Aug 2005
    West London
    850
    You need to hold the auto button for about 10 seconds or so and it will sync both sides to the drivers control.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    Dec 2006
    Ireland
    2,538
    Dec 2006
    Ireland
    2,538
    Boydie
    haha he apologised after!
    thanks guys - ill try it on the way home!
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Does this function stay on even when turning the ignition off?
    If so I take it its just the same to return it to independant controls?
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Oct 2006
    99
    as soon as the passenger uses the passenger control it returns to independent operation..
    Dec 2006
    Ireland
    2,538
    Are you also aware that different temperatues can be set depending on which remote is used to unlock the car. My wife prefers the car to be a little warmer than me. I usually have the climate control set at 20. If my remote opens the car its set at 20. If my wife's remote is used it sets to 22.
    Today's useful reading - 11.06 Sportback manual p131.
    Dave R (h5djr)
    Boydie
    ohhhhhhh very interesting
    im the only one that drives it though but id have it on low all the time anyway!
    good lad :D
    Dec 2006
    Ireland
    2,538
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    It is the key which stores the settings and transfers them to the car when the ignition is turned on with the key.
    ahaydock's Avatar
    Oct 2006
    Dorset
    140
    I have to adjust the passengers side to get dual control (after I have held Auto) - is this right? Do you think they can change it via the VAG com?
    A3 2.0TDi Sport, Mauritius Blue, Xenons, Black Leather/Alcantara, BOSE, Heated Seats, Parking Sensors, Light/Rain Sensor Pack, Interior Light Pack, Armrests.
    Dec 2006
    Ireland
    2,538
    isn't it the key that you use to turn the ignition on that does it, rather than the one used to unlock it? have you tried unlocking the car with Mrs h5djr's key then starting it with yours?
    Having just re-read the item in the Manual, your right. It responds to the key rather than the remote.
    On mine, if I press and hold the Auto button it changes the passenger side setting to match the drivers side setting.
    Dave R (h5djr)
    Vertigo1's Avatar
    Jul 2006
    2,574
    Quote Originally Posted by ahaydock
    If you mean what I think you mean, i.e. after pressing auto to sync the two, the left control changes both and the right control "de-syncs" them again, then it sounds like yours is coded for a LHD car somehow.
    ahaydock's Avatar
    Oct 2006
    Dorset
    140
    Quote Originally Posted by Vertigo1
    Thats right, it works the opposite way around - the stealers have my car at the mo so I have asked them, but they didnt know if this was a coding thing.
    Can anyone confirm whether this is a coding thing? TIA.
