rosscotdi
Hi All,
I've bought a set of Xeon convertion kit For my A3 55 Plate.
I'm Having a bit of problems fitting them, All was going fine untill i switched the engine on then after 4-5 seconds they start flickering like mad!
When connected straight over the battery, they are fine or when the engine
aint running.
So i connected a relay in the circuit and took a supply straight from the battery (via a fuse). But now the resistance of the coil must be too high and the D.I.S show's up a lamp fault.
So question really?
I'm i right in saying there is some sort of weird energy saving circuit built into the supply to the headlights? and if so can it be switched off/disabled?
If not i'll have to put the relays in and get resitors to match the resistance of a 55w halogen lamp, i dont really want to do this cause it gets a bit messey.
Help is much appreciated!
Thank Ross
aint running.
So question really?
Thank Ross
