I've noticed a few annoyances re panel alignment on my A3 and wondered if it was the norm and to be accepted or not?
Top pic is where the bonnet lines up with the wing. From the inside (bonnet open) you can see daylight through a gap between the rubber and the wing. No daylight on the drivers side.
The 2nd pic shows the bottom of the boor not aligned properly as is with the drivers side.
Cheers for any info on if any of your cars ar similar?, not sure if i'm making a mountain out of a molehill?
Will pop into the dealership tomoz to see what they say.
