EM TuningMonster Motorsport
    bluetybo's Avatar
    Feb 2006
    Edmonton, Alberta, Canada
    15
    How do I change the air filter?
    I picked up a K & N air filter but it seems a little more difficult to install it than I thought. Any help is greatly appreciated. Thanks.
    [img]/ubbthreads/images/graemlins/confused.gif[/img]
    imported_DSGSport
    Re: How do I change the air filter?
    Is it a drop in filter or is it an induction kit?
    If it is a drop in filter then it is simply a case of undoing all the screws around the edge of the air box. This should lift up and then you can swap the filters over.
    If it is an induction kit have a look here
    http://www.knfilters.com/search/appsearch.aspx
    They normally have instructions on the site.
    Hope this helps.
    bluetybo's Avatar
    Feb 2006
    15
    Thanks,
    Is there any screws on the engine cover, or does it just pop off? [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    The engine cover unclips at the front and then if you pull it back slightly it free's itself from the rubber mounting at the back.
    J.
