Alright folks, just wondering if anyone fitted their own downpipe to their S3 8P?
I'm pretty mechanically minded, have been successful with most thing's I've tackled in the past.
I removed my intake this evening to investigate access to the turbo/downpipe flange bolts, top lambda sensor and to give them all a good blast of penetrating oil prior to tackling this later on in the week or the weekend.
After getting the intake off and having a good look down the back of the engine access from the top is a nightmare as you cannot remove the stock heatshield, one of the flange nuts is completely hidden in behind the exhaust/turbo manifold and all in all it looks like it will be a nightmare tbh!
Prop disconnection I'm not worried about, removing the actual exhaust sections again don't look like it will be a problem, I've had problems in the past with lambda sensors but hopefully I'll get them out as have a proper lambda wrench.
Can anyone give me reassurance that the upper rear flange nut is more accessable from underneath??
Any other tips?
Cheers!
Any other tips?
Cheers!
