Just got our 1st Audi (a3 Sportback 2009)
mreco99
NULL
Hi
Love the car so far!
Couple of questions if you can help
As its second hand we have no idea what trim level it is? or what options were fitted. The manual goes on about all sorts of things which we don't think we have (but we might!)
Looking on the Audi site now, there are three trim levels SE sport and s line? were they the same back in 2009?
I know we have a 1.4 sport TFSI automatic.
Any help appreciated.
MrE
Welcome to the site.
Thing is if its sline, sport, se etc, things can be added to the standard spec & audi change there minds often what comes with spec levels, however you ideally need the a3 8p brochure for that year to check standard fittings, then check the manual for systems that may have been added extra on top of spec.
Anything that's not standard & you wanted, technology wise, we can fit if ever requested too :)
They vary so much, mines an s-line but hasn't got steering wheel controls or an arm rest, but has full leather! We'll annoying, also whoever bought it new chose a ****** multi changer. Lol
Thanks, I know some bits that were probably extra are there, like climate control, phone socket in arm rest, no leather. Nice red bit in the seats though.
Do you think its worth contacting the original Audi dealer to see if they have a record? I know which Audi dealer sold it.
TBH its not really worth it imho, you can see any extra's like buttons etc, everything that's extra should be mostly obvious.
Printed label in the boot floor or in the handbook provides the build codes and extras fitted to the car. Then Google the codes.
thanks
I will look for the label in the boot, non in the manual I think.
ill get a pic soon
Hi mate, welcome to the club.
as MrLapou says, look for the codes label (..it's inside the front cover of the service book) and enter each 3 digit code from the bottom half of the panel into the box linked below, separate by a , to find out what options were factory fitted. Anything not listed will be retrofitted either by a dealer or a previous owner\independent.
VW Group Option Codes Decoder
my car's options are below. ;)
Reactions: blue10
Your a star, i see all the codes in the service book. Would never have known what they were lol
What do you think, standard spec?
E0A = No special edition
1KD = Disc brakes, rear
3FA = Without roof insert (standard roof)
F0A = No special purpose vehicle, standard equipment
TU0 = 4-cylinder gasoline engine 1.4 L unit 03C.K
1XX = Leather trimmed multi-function sports steering wheel w/ Tiptronic
7Q0 = Without navigation device
3L3 = Manual height adjustment for front seats
1SA = Without additional front underbody guard
7A0 = Without CD changer/CD player
J0L = Battery 340 A (70 Ah)
UA1 = Rear shock absorption
3NZ = Rear seat bench unsplit, backrest split folding
C9V = Alloy wheels 7.5J x 17
UG1 = Hill hold control
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
1ZE = Disc brakes, front (Geomet D)
G32 = Front shock absorption
8GU = Alternator 140 A
8BD = Halogen headlight
8Q1 = Headlight-range adjustment
7K0 = Without tire pressure warning light
4KC = Side and rear windows in heat-insulatingglass
7MG = Emission standard EU5
6XD = Exterior mirrors: electrically adjustable/heated
5TD = Decorative aluminum inserts
U1B = Instrument insert with mph speedometer, clock, tachometer and trip odometer
9Q2 = Multi-function display/on-board computerwith check control
4X3 = Side air bag front with curtain air bag
3Y6 = Sun screen for rear window
5SJ = Left exterior mirror: convex
1AS = Electronic stabilization program (ESP)
7X0 = Without park distance control
0YF = Weight range 6 installation control only, no requirement forecast
X2B = National sales program Great Britain
8Z5 = Not hot country
4K4 = Radio remote controlled central locking
QG1 = Service interval prolongation
5RU = Right exterior mirror: convex (large viewing field)
4R4 = Power windows with comfort operation andcircuit breaker
L55 = Suspension range 55 installation control only, no requirement forecast
1N3 = Speed-related variable steering assist (Servotronic)
D33 = 4-cyl. gasoline engine 1.4 l/92 kW 4V TFSI Base engine is TU0/TL1
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
4GQ = Windshield in heat-insulating glass
