Badger5EM Tuning
Results 1 to 7 of 7
    prt57's Avatar
    Dec 2006
    243
    How to remove the hose clamp in order to fit a CAI on an S3?
    Hi,
    I have been thinking about fitting a CAI to my S3 8P but at the moment I am wondering how do you undo the nasty hose clamp where the plastic tube from the original air filter goes down the back of the engine to the RHS of the master cylinder?
    There is not a lot of access and so the conventional plumbers pipe grips or squeezy clamps have no room to get a grip.
    Would I be correct in thinking that these would do the job?
    BGS - Flexi Ratchet Hose Clamp Pliers For Fuel & Coolant Hose Clips 630mm Bowden | eBay
    Also if this is the correct tool, do you attack this clip from the top or up from underneath?
    What is the current thinking of CAI quality and fitment? I am only interested in a super quality item where appearance is excellent and there are no issues in the fitting.
    Thank you,
    Peter
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Having just removed my Evoms CAI I have a lot of sympathy for you. That bottom clip is a right pain to get to but you really have to persevere and eventually you'll get it off.
    Hopefully your replacement CAI will come complete with jubilee clips which makes the fitting job a cinch in comparison. If not you need to buy a 70-90mm jubilee clip. Don't even bother trying to refit the original clip, I gave up after 45 minutes. My hands don't have the dexterity they used to have!
    8P2 S3
    prt57's Avatar
    Dec 2006
    243
    Quote Originally Posted by Staz View Post
    Thanks for the reply, but what did you use to get the clip off?
    Regards,
    Peter
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I did mine a few years ago so I have no idea, probably just adjustable pliers. I remember it being a pain but not that bad.
    8P2 S3
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    A remote tool as you've linked makes it easy, so do long nosed pliers. Done several never had a problem using either of those two.
    JamesS4cab's Avatar
    Mar 2008
    1,122
    I used an adjustable wrench and set it to the width of the clamp when it was closed that would mean that the wrench was fully pinched together. I put a cable tie on the handle so when i had it fully pinched i could clamp the wrench shut using the cable tie and then just move the clip upwards and out the way. Then its just pulling the hose (oooo er missus) until it comes off. Took about 10 mins all in.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,485
    I use this takes seconds to fit and take off.
    Hose Clip Pliers for Constant Tension Clamps. T247302 | eBay
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
  1. How to remove the front headlight
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2013, 12:26
  2. How to remove the front light clusters?
    By auditurboquat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th August 2007, 18:44
  3. How to remove the Front Seats? Any Body?
    By Offtrack4Speed in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2007, 18:54
  4. how do remove the climate control unit
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2006, 22:53
  5. Advice on how to remove the top control arm pinch bolt..
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2006, 19:06
