EM TuningAH Fabrications
    Jun 2013
    Norway
    20
    Angry Engine check light on
    Hi
    Last night a friend of mine replaced the "throttle" and cleaned the egr valve.
    The car was more responsive on the throttle and all in all felt better.
    For some reason, the ECON was on, wich means the ac unit doesnt work, he said that ac fan 1 come up as faulty on the vagcom, wich is ok, but when i turned of the ignition and fired it back up, the ECON was off and the AC seemed to work?!?
    The main concern is that the check engine light is now on, the car runs fine as it did last night, but the check engine light worries me, because this car has been an headache from the getgo.
    I dont have vagcom available here at work, and im sitting here and wondering what can be wrong this time?
    any ideas?
    Kind Regards
    Ole
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    did he replace the throttle body if so maybe he didn't have it closed when he put it on ? check the wires are in properly.. your best bet is VCDS.. and take it to a workshop it might be a small issue and turn into a big one
    Jun 2013
    Norway
    20
    Quote Originally Posted by Sevv View Post
    I have talked to him, the fan the comes up in CVDS as faulty also has the function of cooling the engine, he will take a look at it tonight. ill keep u posten, thanks for the advice btw.
  1. Dash lights/engine check lights stay on for ages after starting
    By mikeyc_123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2012, 21:16
  2. EPC light and engine check light
    By musty in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2012, 08:40
  3. VAGcom and engine check light
    By Datsun in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2012, 07:34
  4. 2001 Allroad A6 TDI 2.5 180 Engine Check Light
    By Rossy in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th June 2011, 22:24
  5. engine check light
    By audii in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th August 2007, 17:23
