Badger5AH Fabrications
Results 1 to 27 of 27
Like Tree4Likes
  • 1 Post By S3_Jacko
  • 1 Post By DarkBunny
  • 1 Post By tcardio
Thread: Fuel tank half full - click...
    Jul 2013
    Cambridgeshire
    279
    Don't know if this is just Tesco pumps but since I've had the car it seems to take forever to 'find' a point where the fuel will just fill up without constant clicking and manouvering...
    Well today, I managed to get half a tank in then the same - click, click, click, click - oh crumbs fuel is coming out of the filler neck!
    As there is only half a tank of fuel, what could stop more going in - the first half went in fine (albeit with a few points of finding the 'spot')...??
    2007 A3 S Line Quattro 170 TDi
    27,114
    How much interms of cost is the half tank total?
    Jun 2013
    25
    Could be an air lock, or maybe the fuel level sensor isn't functioning correctly. Have you correlated miles driven to fuel used, just to be sure?
    Don't have this issue with my A3... any pump, any nozzle angle, seems to be fine.
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    904
    I found (also at Tescos) that i had to rotate the nozzle a bit for it to flow quicker,compared to my last petrol car.Not sure if it's the different nozzle or not.
    Growing old is mandatory, growing up is optional
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    493
    Dont stick the nozzle in as far, i had a similar issue with mine where i was empty but yet it was still clicking and not allowing any diesel to enter.
    Jul 2013
    Cambridgeshire
    279
    £35 quid.
    Quote Originally Posted by A3_Mayhem View Post
    The tank was in reserve (as i'd done 450 miles from full). It only took 25 litres before clicking...
    Quote Originally Posted by LEE69 View Post
    Will have to try another garage to see whats it's like - just didn't expect it to spit my fuel back out at me, thought the nozzle was just misbehaving!
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,219
    Happens to my old mans passat, I just stick the pump bit a bit and let it flow in slowly rather than full flow
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Oct 2012
    139
    Happens to me in some places. Just withdraw the nozzle very slightly and then twist slightly. Solves it every time.
    It's the design of the neck of the fuel tank not being able to cope with modern high speed pumps that have sensitive auto cut offs.
    Mind you, rather than that covering yourself in petrol as I did once with my first car. Merrily filling her up, no click and petrol everywhere!
    Jul 2013
    Cambridgeshire
    279
    When I took the nozzle out the fuel wasn't flowing down the pipe though, just sat there.
    Then the fuel that had spilled into the overflow hole went all over the floor...
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,292
    Quote Originally Posted by DarkBunny View Post
    Same issue with mine at tesco... Need to put it in far enough and twist in all directions to get full flow, usually click click click or very slow flow...
    i'd put it down to **** pumps and nothing wrong with your car...
    Every little helps!
    DarkBunny likes this.
    Oct 2012
    139
    Quote Originally Posted by S3_Jacko View Post
    Every little helps!
    A car refusing supermarket diesel is a car with good taste. I'd do the same if you offered me their own brand cola.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,292
    Quote Originally Posted by chinnyhill10 View Post
    Its the 99-octane super unleaded I use... Highest octane fuel i've found... Prob cos that pump doesnt get used that much cos its far more expensive than regular unleaded
    OVRA3 likes this.
    Jun 2010
    65
    I find turning the pump through 180 degrees works everytime, so you're doing it sort of upside down. That's in my 2004 2.0 tdi. It'll be interesting when I pick up my 2009 sportback next week, to see if it's still the same!
    Oct 2012
    139
    It's a Golf platform thing. My Golf MK5 was a pain with certain pumps as well.
    Jul 2013
    Cambridgeshire
    279
    Right then - update...
    Gone to another fuel station and I've had the same thing. This time finishing up with just over half a tank in the car.
    Filling it really slowly to ensure that it's going down the pipe and around half full I hear the pipe filling up (sloshing and glurgling) to a point, then click. Left it for nearly a minute and managed to get another litre in, but the same. Now I cannot stand at a pump for another 25 minutes to get anotehr 25 litres in... So what could be the issue?
    Does anyone have a parts image of the tank and filler neck - just want to see if there are any obvious kinks, bends, air blockages that could cause this.
    Thanks!
    Jul 2013
    Cambridgeshire
    279
    Think I'm going to have to call the warranty company and see what's what. Guess I maybe looking at a new filler neck as there is obviously an issue there.
    Jul 2013
    Cambridgeshire
    279
    So - still have this issue and the warranty 'doesn't cover it'... What a f*^king surprise.
    I put as much as I could in yesterday, drove 10 miles then put another 15 litres in. Still nowhere near full though. Can the breather system get blocked up?
    Am I looking at dropping the tank and replacing the pipe??
    Jul 2013
    Cambridgeshire
    279
    Does anyone else have any thoughts or advice on this? It's still happening and I'm stumped (so are Audi)...
    Same issue, half tank - fuel in filler pipe, another 10 miles - can add another 10 litres or so...
    Why would it be so slow for fuel to get into the tank?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    "Any thoughts?"
    I think something may be floating in the tank and rising up with the fuel level to block the bottom of the filler neck. How you would prove that is beyond me though.
    2009 A3 SB 2.0T DSG S line
    27,114
    Remove the lift pump from under back seats, 4wd has 2, 1 on each side of center of the car, empty tank, have a gander inside with torch, clean as necessary, test filling with maybe fuel or water if you're sure it can all be flushed out, safer aswell, so you can see it coming in when pumps out, making sure to disconnect pipes to engine in the bay & filters, see what it does then.
    I would also disconnect/bung lines on tank/s to the front so it stays in the tank, see if this makes any difference.
    If it seems ok then refit all after cleaning any residual liquid, water out completely, then fill with say 5-10 litres of fuel, flush through the lines to a bucket or the like in the bay, so it gets rid of water with luck, then test again.
    If continues then need to remove all & inspect tbh, tank out, feeder pipes, change lines, lift pump, etc etc.
    Tonka Toy's Avatar
    Dec 2013
    Hertfordshire
    119
    If he hasn't got a torch.., would a lit match do???
    Jul 2013
    Cambridgeshire
    279
    Thanks Nigel. Best get the tools out!
    You've reminded me that I need to book you in for a Cruise retrofit too ;-)
    NHN likes this.
    27,114
    About time :P
    I'm about next week aswell.
    Sep 2009
    Trotters, Peckham
    539
    Remove the lift pump from under back seats, 4wd has 2, 1 on each side of center of the car, empty tank, have a gander inside with FLASHLIGHT, clean as necessary, test filling with maybe fuel or water if you're sure it can all be flushed out, safer aswell, so you can see it coming in when pumps out, making sure to disconnect pipes to engine in the bay & filters, see what it does then.
    Just needed to amend for the visiting Americans
    NHN likes this.
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Mine has a really sensitive filler neck as well, I practically need to take a meal with me when I go fill up, never had so much trouble putting fuel in a car before this!
    27,114
    I was chatting with my audi guys today & he was suggesting an issue with the breather pipe/s.
  28. #27
    Jul 2013
    Cambridgeshire
    279
    That's what I thought originally, but looking at pictures of the tank and pipe work, there certainly seem to be a few of them! Where the chuff do you start!
  1. Fuel tank full or not
    By Brodster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2013, 13:43
  2. Fuel tank/warning/guage oddness
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st August 2008, 15:54
  3. petrol leak when tank is full....
    By abdus in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2007, 21:57
  4. 2.5 TDI Quat won't start - electric pump in fuel tank help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2007, 10:41
  5. Fuel Indicates half even filled it up
    By lwen in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2004, 19:48
