Chris NottJMB Retrofits
Results 1 to 17 of 17
    Jun 2013
    176
    Why is my rpm jumpy
    Jumpy rpm needle audi a3 8p - YouTube
    Tried cleaning the throttle body, maf sensor, changing the spark plugs, cleaning the engine. But the problem stil occurs. Any idea on this guys? Possibly a vacuum leak? If so, where is the first thing I should look?
    Mar 2010
    14
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    With a warm engine, try removing the oil filler cap while car idles to see if that makes a difference. In a normal engine, it'll make revs fall and rise.
    Jun 2013
    176
    Quote Originally Posted by MrLapou View Post
    Warm engine, coolant at 90 degrees. Removed the oil cap, no noticable differnce. Engine shaking just slighrly but not that much when removed. Tried with the dipstick, no signs of difference
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Ok. then it points to a vacuum leak.
    Do you have access to VCDS or a blue tooth OBD2 dongle plus Android phone running Torque?
    Thay way vacuum can be monitored.
    Jun 2013
    176
    I have a CAN obd2, i can diagnos a car but cant write. What parameter should i look at mate?
    Jun 2013
    176
    Sorry, but need to bring this thread to life, as i am still having the problem.
    Well i now have access to vcds. I assume i am going to engine 01 > then?
    I also tried removing the pcv valve from the engine block itself. I then started the engine. Rpm raises about 2000rpm then back to 777 RPM then back to 2k RPM. Needle was still jumpy when that was removed. Any more ideas?
    I only have a NOX sensor fault in vcds. But that might not be the problem?
    Jun 2013
    176
    Engine is also "choking" in idle. After driving the car an hour or two. Here is a video of ot choking
    http://youtu.be/4iWFxE1AnVk
    When its choking. It does this every 30-ish second...
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,032
    Holy thread revival. Sounds like PCV failure if its a lumpy idle with hunting revs.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Jun 2013
    176
    Quote Originally Posted by wuta3 View Post
    What i thought too. I dont think it is the pcv. Removing it will not remove the jumpy needle issue. But after researching, the EGR (exhaust gas recirculation) unite might need to be cleaned. The EGR is located right beside/behind the throttle body. It contains gears that maybe broke (cheap plastic gear) or just clogged up. Will check on this tomorrow or sunday. They say that it is a simple process looking at this. Will give feedback on this!
    Jun 2013
    176
    Here is the egr valve btw
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,448
    check the DV mate for any splits
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    Jun 2013
    176
    Why is my rpm jumpy
    Quote Originally Posted by RedDejavu View Post
    You mean the diverter right? Dont have it, as my engine is N/A
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,448
    ahh ok you didnt state what engine it is
    Now:
    Jun 2013
    176
    Upps, my mistake then!
    Jun 2013
    176
    Update: removing just the connector didnt make any change
    Jun 2013
    176
    Why is my rpm jumpy
    Update 2: removed the top lid on the egr. Lots of dirt, cleaned it. No change.
    Tried removing the 4 T-30 screws. But ended up with stripping the torx bit in half. No more updates.
  1. Why did Audi leave WRC?
    By AL_B in forum Motorsport
    Last Post: 26th June 2006, 17:34
  2. Why dont Audi
    By richyboy in forum Diesel forum
    Last Post: 27th February 2005, 23:39
  3. Why does this 5000 quit on its own??
    By Sabre60 in forum Classic Audi Forum
    Last Post: 5th May 2004, 01:40
  4. Noise at 2k rpm
    By S3_quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2003, 14:52
  5. Problems engine rpm
    By Ciril in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2003, 19:45
