JMB RetrofitsChris Nott
Results 1 to 17 of 17
    Feb 2013
    Grimsby
    1,094
    bought new cam follower, fuel pump looks different to one in video
    So iv got my new cam follower and i was going to try replace it, however after watching this tutorial video
    DIY: 2.0T FSI Cam Follower Replacement on Vimeo at 4:30 he has a bleeder valve, mine does not have this and has a metal pipe connected around that area instead.
    Its an 05 2.0 TFSI. so not sure what to do now, would i be able to leave them attached and still replace the follower? or would i break something.
    Thanks JJ.
    Feb 2013
    Grimsby
    1,094
    the 2 pipes on the bottom, where on the video it has a bleeder valve, what do?
    Uploaded with ImageShack.us
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    its only to let the preasure out
    just pull the fuel pump fuse start the car all preasure is gone
    then remove pump etc
    Marc8490's Avatar
    Apr 2013
    Montrose, Scotland
    21
    Have you fitted your fuel pump yet? Either on your new 1 or probably best on your old one once you've removed it could you do me a favour? The union on the bottom at the right hand side could u take that union off and tell me if there's anything inside it? Removed mine by accident and heard something falling into the engine bay but cant find anything, thinking there's possibly a tapered pin in there
    Feb 2013
    Grimsby
    1,094
    Quote Originally Posted by Marc8490 View Post
    Yeah i saw your thread and got worried when doing mine, thats why i went to check and noticed it was diffrent. Is yours the same pump as mine?
    JJ
    bez101's Avatar
    Jul 2008
    8,480
    there shouldnt be anything in the union
    iv remved quite a few and never seen anything in there
    Marc8490's Avatar
    Apr 2013
    Montrose, Scotland
    21
    No i had the bleed valve on mine, like bez said start it with the fuse pulled, my car had been sitting all night and went out this morning to work on it and there was no pressure behind the bleed valve.
    but i removed the union when i didnt need to doh ha, just dont take the union off u only need to take the hard pipe off of the union, but if you could take the union off once uve got the fuel pump on a work bench and tell me if anything is in there behind the union that would be a massive help
    Marc8490's Avatar
    Apr 2013
    Montrose, Scotland
    21
    Cheers bez, hmmm something fell in to the engine bay about the same time i took the union off, make it was just a coincidence and it was something totally different, also feel there's a lag in the throttle response since i changed the follower, mabye there's always been lag ive just never noticed it :/
    bez101's Avatar
    Jul 2008
    8,480
    have you got VCDS ?
    if there was a fault at the HPFP it would have a fault code stored
    Marc8490's Avatar
    Apr 2013
    Montrose, Scotland
    21
    Yeh i do, but last time i tried using it there was something up with it, ill try it again tho
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Hmm, I might tackle this too.
    58 plate S3 with 29k, is it worth doing it?
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Marc8490's Avatar
    Apr 2013
    Montrose, Scotland
    21
    Mine is 07 70k miles and i would say it wasnt that bad, but I don't know if it been done b4, possibly has
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,896
    Quote Originally Posted by crunchie View Post
    I believe the risk is low but just for piece of mind and the cost of it its worth doing.
    XFi
    Jun 2010
    344
    I have a 58 S3 and I changed my cam follower about 3000 miles ago at 70k. The old one was fine with minimal wear but for £25 and peace of mind it's worth doing.
    Feb 2013
    Grimsby
    1,094
    Mine has 120k on it and no idea if it has been done before... :O
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    I change mine every 10k alongside with the oil service.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    Aug 2013
    Durham
    12
    Mine has failed badly at 72k so I would definitely be checking on changing them
  1. Fit the new cam follower yesterday.... Snapped a pipe 2.0tfsi quattro BUL
    By Craig Cull in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd January 2013, 12:58
  2. 2.0T cam follower replacement and look how bad this is!!
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th October 2011, 20:11
  3. TFSI Fuel pump cam follower
    By KRL in forum Parts Requests
    Last Post: 2nd February 2010, 14:43
  4. had to have new ECU and fuel pump!!
    By Icarter in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd September 2009, 12:45
  5. high pressure fuel pump-take a look at this picture!!
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2007, 22:33
