JMB RetrofitsSky Insurance
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By Boydie
Thread: Droopy Gap
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,061
    Droopy Gap
    Hi all,
    searched about couldn't find a solution. Door drop resulting in a gap at the top. Not sure if they are independently adjustable. Also, not sure what caused the wear on the pillar. Any help/ideas on fixing the drop?
    (notice the wear above the door corner and the drop. It doesn't look too bad in the pic but is about 4mm)
    Normal?
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Aug 2012
    Essex
    73
    hinge or catch alignment? no idea! Mine sits tight tbh.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    door catch can be adjusted
    wuta3's Avatar
    Jul 2012
    1,061
    So it's the catch not the hinge? Any idea how I adjust?
    bez101's Avatar
    Jul 2008
    8,480
    it could be the hindge
    look at the catch you will see just loosen the screws and adjust till you get it right
    wuta3's Avatar
    Jul 2012
    1,061
    Just been outside, can't see any catch adjustment ... do you mean the metal loop bit on the pillar or the catch/lock bit in the door?
    bez101's Avatar
    Jul 2008
    8,480
    yes sorry on the pillar side
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    It's probably the door dropping on the hinge. It is quite common and there was a thread on it recently.
    VCDS USER
    Jul 2013
    Cambridgeshire
    276
    I would certainly say door dropping from the hinge aswell - it shouldn't go that low.
    You've not by any chance had someone/something hanging off it while the door was open have you?!
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Yeah I have this problem too on my passenger side - haven't had an opportunity though to investigate it but my guess it is at the hinge.
    wuta3's Avatar
    Jul 2012
    1,061
    Quote Originally Posted by DarkBunny View Post
    Na both doors are the same. Not got any worse since I bought it ... just trying to work out how to fix it lol
    Jord's Avatar
    Dec 2010
    Ellesmere port
    273
    I've got the same problem, I'm gonna try jacking the door to pop it back, big brutal I know, but few of mk4 golf lads have done the same
    Jul 2013
    West Mids
    65
    Not been in a bump in its past life would you know ?
    wuta3's Avatar
    Jul 2012
    1,061
    Quote Originally Posted by OFFSKEE View Post
    Door drop is common, not a reason to suspect a bump. esp when the drop is the same on both sides.
    Jul 2013
    West Mids
    65
    Didn't mean to come across negative fella it's just that this is not uncommon with cut and shuts. Hinges can be adjusted by the way but best by removing the door first. Depending how much you need to move each one.
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Its a common problem across the majority of modern vags - a good mate is a seat mechanic and they get them in quite often but they contract it out elsewhere.
    Jacking it up won't help unless you loosen the door first, jack/lift it up then tighten again.
    OFFSKEE likes this.
    Mar 2012
    369
    Just had a look at my Haynes manual - it says you can do limited adjustment on the top hinge.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    Hows the bottom of the door. Post a pic
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Quote Originally Posted by SL11 CKK View Post
    My passenger door dropped to the extent that the bottom plastic lip chipped the paint of the car metal chassis.
    VCDS USER
  1. S3 Spark Plug Gaps
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2006, 21:07
  2. Gap Insurance
    By sharpr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th August 2005, 19:53
  3. Audi GAP insurance and fixed cost maintenance
    By Greytop in forum Detailing
    Last Post: 11th January 2005, 13:26
  4. GAP Insurance
    By imported_RedSportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2004, 22:20
  5. A4 2000 - Gaps around HU
    By imported_Cali in forum In-Car Entertainment
    Last Post: 9th August 2004, 22:50
