Monster MotorsportVolks Autos
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Boon
  • 1 Post By VagPro
Thread: Gearbox removal guide
    Feb 2008
    24
    Guys,
    Im about to change clutch and flywheel on my 2004 A3 2.0 tdi however Im struggling to find a decent guide anywhere.
    Ive replaced clutches before so not overly worried, its just nice to see it having been replaced before and know where to look for hidden bolts etc.
    Can anyone point me in the right direction (yes.. Ive searched allready)
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    I've never done it before but would probably try and look into getting Haynes Manual.
    VCDS USER
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    311
    Quote Originally Posted by Frazzly View Post
    Guys,
    What's your engine and gearbox code and ill post the section from ELSA on here
    Regards
    Facebook.com/vprouk
    Feb 2008
    24
    Unsure on gearbox but its a BKD engine if that helps. 6 speed manual box
    Mar 2013
    56
    Give your local Audi dealer a call and quote your VIN and they should be able to tell you
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,911
    my quick guide
    call john (my pal)
    and let him do the graft.
    Boon's Avatar
    Sep 2012
    South East Kent
    338
    Rather a short guide but quite involved!
    Remove air filter & pipe work
    Remove battery & tray
    Disconnect gear selector on top of gearbox
    Disconnect clutch hydraulics
    Remove under tray
    Remove drive shafts
    Crack off the bell housing bolts
    Secure the engine
    Remove top gearbox mount
    Undo dogbone mount
    Remove bell housing bolts
    Ease gearbox away from engine
    Remove gearbox from under the car
    Prob missed something but goes along the lines of that!
    Frazzly likes this.
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    autolatry's Avatar
    Jan 2013
    Yorkshire
    347
    Feb 2011
    311
    A3 2.0 TDI GRF Gbox code Clutch replacement
    If this is not your gearbox then the code should be on a sticker in the boot
    Feb 2008
    24
    For everyones benefit I finally got round to replacing flywheel, clutch and slave cylinder today.
    Appears to be an easy job ignoring the weight of the box and jiggery pokery to get it back on.
    I also got a bargain from carparts4less, euro car parts sister company.
    Sachs dual mass flywheel, Sachs clutch kit and sachs slave cylinder for £292 posted.
    Bargaintastic
    The old LUK clutch plate wasnt too worn however the flywheel was absolutely wrecked, roughly 15-20mm of play in all directions.
    Im surprised it wasnt louder in the car!
  1. 1.9 tdi gearbox removal guide needed!
    By glenandem in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd May 2013, 18:36
  2. Gearbox removal
    By smo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2009, 18:40
  3. A3 8L Quattro gearbox removal please HELP
    By A3Quattro1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2009, 18:27
  4. A3 Quattro Gearbox Removal
    By A3Quattro1985 in forum General Technical / How To
    Last Post: 24th January 2009, 00:00
  5. a3 quattro gearbox removal??
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2007, 20:52
