Badger5Chris Nott
Results 1 to 22 of 22
Like Tree9Likes
  • 1 Post By sliced
  • 1 Post By TDI140
  • 1 Post By phil76
  • 1 Post By TDI140
  • 1 Post By PaulAr
  • 1 Post By gilberto
  • 1 Post By S3Alex
  • 1 Post By S3Alex
  • 1 Post By NHN
Thread: My expectation too high?
    Mar 2010
    Somewhere
    324
    Hi folks
    Had revo install today on my S3
    As I put my foot down I dont feel that pull like my previous audi a3 which is 2.0T front wheel drive
    I have three things in mind
    -Do i need to let it settle for couple of days before i notice anything
    -Due to the weight of the S3 it does pull little bit better than stock
    -Am I expecting too much from stage 1?
    Thank you
    27,033
    Maybe it was already mapped :P
    Should be obviously noticeable tbh.
    Mar 2010
    Somewhere
    324
    but it doesnt throw me back to the seat when I put my foot down
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,199
    check out the thread about the Diverter valves
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Mar 2010
    Somewhere
    324
    Quote Originally Posted by sliced View Post
    I have asked to garage guy he said it doesn't need to be change
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Don't forget....it's no lightweight at 1500kgs,and the power/weight ratio at Stg1 is about 200bhp/tonne.
    It will be brisk,but not scary.
    Also,the ECU will adapt for a period of time following the remap,and there may also be parameters like boost which need tailoring to your own preferences,but for it to feel fast,you may need more power.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    I found stage 1 wasn't had i'd had in previous cars ass dyno wise, but it definetly is quicker by stopwatch.
    sliced's Avatar
    Jun 2012
    1,199
    HI mate, you could get it dyno'ed and see what power its laying down. If its quite far of what it should be doing then you could investigate
    I oOEddOo I likes this.
    Mar 2010
    Somewhere
    324
    Quote Originally Posted by S3Alex View Post
    The mechanics got me excited saying u should feel it straight away
    Yes I guess my old A3 is lighter and only a front wheel drive so it feels very quick and throw me back to the seat
    I see in these couple of days let the ECU settle first
    Jul 2010
    561
    I'd definitely want the DV checked. Did your mechanic actually inspect the membrane?
    Sounds like you need to get it on a rolling road and see what's going on.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Quote Originally Posted by I oOEddOo I View Post
    I would go with that.
    As was said above,the real proof is against the clock,and the S3 can be deceptively fast,without ever feeling neck-snappingly fast.
    I certainly felt Stg1 was worthwhile,and made the car much more usable overall,with a good deal more torque,and after a couple of days,you may well notice that,compared to what it was like before.....try it at around 3500-4000rpm and see how it pulls.
    Also,different maps may be set up differently,and will therefore feel very different in use,although it is true that an aggressive map may actually not be as quick as a more linear one.
    Mar 2010
    Somewhere
    324
    Yh will do pal cheers
    TDI140's Avatar
    May 2011
    1,329
    This is the reason i say go to reputable tuners and tuners that have dyno's for before and after printouts, for all you know hes given you a 10bhp increase that you cant even notice
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    556
    Dyno'd you should be hoping to see 290-310 bhp depending on the dyno,like people say let it adapt,use good fuel v-power etc if you dont already,intake always good for helping them rev out through the gears,maybe stick a set of nology plugs in it,they arent necking snappingly fast stage1 or really any but the pull through 3rd and 4th should have you a bit more excited than you sound,i would also say check the DV for the sake of it
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    TDI140's Avatar
    May 2011
    1,329
    Your dyno result should be 305-310bhp on a decent stage 1 map, the s3's produce alot of power
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    You should notice a big difference between stock and Stage 1.
    What are your REVO settings?
    If they are set too conservative then that could be the issue.
    NHN likes this.
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    Jan 2009
    125
    Hi folks
    Thank you
    I had the same thoughts when i went to Revo Stage 1, give it a few days, the S3's a really smooth car but decepively quick.
    Mar 2010
    Somewhere
    324
    Quote Originally Posted by gilberto View Post
    I am on revo stage 1 too hopefully the ECU adapting soon
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Mine made around 310 bhp on Stg1,but as I said,it doesn't feel neck-snappingly fast,but is a lot more usable than stock.
    More torque,a bit more bhp,and better to drive....don't expect miracles from Stg1,it's more of the start of the slippery slope to more power!
    27,033
    How can you say that when it got you addicted in the 1st place :P
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    LOL...and like I said....it's the start of the slippery slope.
    It just made me think this car cries out for more power,and then more,and then some more after that!
    27,033
    and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more and then some more
    Ooops sorry my S3Alex special keyboard got stuck lmao
    S3Alex likes this.
  1. will this sit too high?
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2006, 13:22
  2. S3 Driving Position - Too High?
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 14:59
  3. X-post for a friend: A3 Oil consumption too high
    By ImolaS4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 13:13
  4. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
  5. Too high Service Costs?
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2003, 19:17
