Monster MotorsportBadger5
Results 1 to 20 of 20
    Jun 2013
    Cumbria
    202
    Cooling fan removal guide?
    Has anyone got a guide to removing the cooling fan on my audi a3 2.0 tdi 53 plate? The guy at the garage recons I need to take the full bumper off to remove the full unit. Not quit sure how to go about it. Any help is appreciated!
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by Tommy53 View Post
    I would take the front end off its easy takes about half an hour to remove the bumper and crossmember
    Jun 2013
    Cumbria
    202
    So once the front bumpers off I can get to where I need to? Where's the module aswel, he said take that off. Sure it's down at the bottom right!
    Apr 2013
    Aberdeenshire
    592
    Is your battery under the bonnet or in the boot mine is a 3.2 so my battery is in the boot and my fan module is integrated to the fan however yours could be a separate module beside the battery if its under the bonnet "just like a golf"
    the radiator sits on rubber bushes and is held from the front with two Torx screws left and right then the whole fan assembly is fixed to it left and right from the bonnet outward by two Torx . I did it a year ago so that's how I remember it.
    is your water pump ok as vag water pumps had issues with the pump breaking off the drive as impellers were plastic check for a return at the top of the tank also if the heating works at idle however did you find a coolant leak ?
    Jun 2013
    Cumbria
    202
    Yeah my battery's under the bonnet mate. Just got a feeling the modules near it on its own? Rightio thanks will There be some aircon cables attatached? Also would you recommend disconnecting the battery? Ill check that soon as I'm about to go tackle it now. Currently not found the cause of the coolant, the mechanic wants to check and possibly replace the cooling fan, cos they aren't running atall and as you can imagine its getting pretty hot under the bonnet and that could cause even more damage.
    He did check for exhaust gasses in the coolant with that blue liquid stuff? And nothing showed up! Gonna take the egr cooler off also I think, just need to figure out what to block/ clamp the two coolant pipes with
    Jun 2013
    Cumbria
    202
    Also I'm sure my water pump is ok, iill have a look. Was changed 30k ago
    Apr 2013
    Aberdeenshire
    592
    I never reclaimed my a/c I just supported the rad with cable ties its probably the j293 module if you google images or audi fan mmodules never disconnected the bat it but its wise to and wait due to the crash sensor top right and left I would have your car scanned with vcds though
    Jun 2013
    Cumbria
    202
    The guy scanned it the other day and there was faults on the cooling fan and module mate. What do you think of this and would you say it's normal? It's the cover under the wheel arch on the battery side, that looks like it sits under the intercooler pipe?
    Hopefully the pic will work!
    Apr 2013
    Aberdeenshire
    592
    Radiators are common at the ends but is your battery ok as it would be above that area it looks like its been eaten through with acid does it smell sweet ish like coolant ?
    my understanding of module is it is a couple of relay nothing too fancy sure I saw a diagram some place.
    unless you have a leaking intercooler
    Jun 2013
    Cumbria
    202
    Does smell sweet but battery was changed a few days ago. Ahh right bumpers off now. Tryna figure out how to get this radiator/ fan off
    tdi-man's Avatar
    Jul 2009
    1,611
    cooling fans can be removed in under 10 minutes if you have a ramp I did mine at m8s garage no need to remove front end
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Jun 2013
    Cumbria
    202
    Bloody hell mate, you tell me that once the front ends off ha how do I do it?? I've taken two torque screws out from the front, but not sure which other ones need to come out
    Apr 2013
    Aberdeenshire
    592
    Two Torx from under the bonnet on the fan assembly panel right an left.
    TDI140's Avatar
    May 2011
    1,349
    Lol i was about to say same thing dont need to remove bunper or anything i did mine last month one fan was dodgy did it in 20mins in and out on my drive bit fiddle as its dark but easy enough
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Jun 2013
    Cumbria
    202
    Haha cheers. I've identified the four screws however getting to the ones on the battery side looks difficult
    Apr 2013
    Aberdeenshire
    592
    i dived in and removed the front as under my bonnet is probably a lot tighter than your never really thought about you having more space for hands.
    Jun 2013
    Cumbria
    202
    Cannot get these two out -.- so close yet so far. Any tips?
    Apr 2013
    Aberdeenshire
    592
    Loosen the crossmember to allow movement I or remove the clamp if possible
    27,086
    Just gently push the pipe aside to undo that one.
    The oil on the arch trim is normal from IC pipes.
    No need to take front end of, fan unit & rad can be removed with bumper in place.
    Jun 2013
    Cumbria
    202
    Thank you all. Got it off now, no need to remove bumper like you's say however it is very limited for space.
  1. Internal heating/cooling fan problem?
    By jakeriddler in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st November 2006, 20:04
  2. Internal heating/cooling fan problem?
    By jakeriddler in forum General Technical / How To
    Last Post: 21st November 2006, 00:00
  3. Electric Cooling fan
    By Robc in forum General Technical / How To
    Last Post: 18th July 2006, 14:43
  4. Cooling fan / viscous coupling
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2006, 08:59
  5. Cooling fans blow backwards?!
    By albany in forum Classic Audi Forum
    Last Post: 17th October 2003, 03:59
