Service indicator
jimick
Anyone tell me how to reset the service indicator on my A3 2ltr 2009 plate
The service indicator light comes on advising the service is due in 7 days but I've just had the service done the garage didn't reset it
It'll need resetting by a garage with the vw VAS system or by a friendly vcds cable owning forum member...
Odd that your garage couldn't do it?
It was done by Arnold Clark I wouldn't expect anything less from them. The fact they were a vauxhall dealership probably didn't help either they did the service as a good will measure for months of problems
Where are you based ? I'm sure a cable friend will help in exchange for beer tokens. It's a 2 minute job.
99.9% sure that DIS stalk method only resets the oil service interval and not the main service. You will need someone to help you with a proper VCDS cable and software. Quick job and sure someone close to you will sort for a bit of beer money :)
Reactions: NHN
Yip your right tried it this morn and it only resets the oil service:sob:
Weird because it worked for me, after I done it "service" displaying on the dis went and It didn't come back on till the usual service in 1500 miles. So I presume your still getting a message on the dis after trying it?.
Yip the service message went but came back after the ignition was switched off and on , the oil service will reset this way :uhm: what year is your a3
Varies with years how the resets are done, eg. doing 08/09 onwards resents via vagcom has been a pita with vcds, but could be done manually instead of using SRI, not sure that's been resolved as yet, but still even manually with vcds is good & quick enough.
493
791
861
7
995
jamiekip
J
