you wont be able to replace it with any sub as it is in a very small enclosure... i would recommend a direct replacement part or going for something like the Andy Mac sub
Is it possible to replace standard Blaupunkt sub woofer with Bose sub woofer in A3/S3 8P? Is connector the same? Amplifier is also in the box? I'm satisfied with sound, especially after fitting RSN-e, just that sub woofer is not up to job, it makes annoying noises, I dampened it somehow but still it's crap compared to the rest of the system.
You can buy your own enclosures of ebay for around £80 similar to Andy's and do your own system if you want...
However i will be keeping an eye on this as im in the same situation
I'm sure it's a 6.5" sub. My blaupunkt one is. I ended up sacking it off totally and fitting a full system in and wiring the rear speakers directly to the head unit
