2003 a3 2.0tdi
i have been fine tuning the cams to cure a vibration and bad idle! The car seems to be runnin okay now at 800 rpm!
I have set the front cam (closest to radiator) to 0.0 kw (torsion value) the rear cam i adjustet untill the car idles smooth! Now i read somewere the consumption should be around 0.6 l/h and the engine torque no lower than 28nm! Now my readings are: 0.6l/h-0.4l/h
and stays at 0.4 l/h when fully warm! And my engine torque moves around from 28-32nm does this sound okay? Also my torque request (driver) is -2.0nm! Are all these readings okay and normal or is there something wrong?
