Volks AutosJMB Retrofits
Results 1 to 32 of 32
    Aug 2010
    160
    injector reading bad?
    my car (140 tdi a3 bkd 99k miles 06 ) is very very poor mpg around town its 26-28 average also starts ok but sounds very rough only one the first start soon as its done a minute or so its fine even if you restart its ok.
    I have changed all filters cleaner inlet manifold removed egr checked all pipe work and everything I could think of I then used a mates vcds to jet injection quantity and they look very out of spec does anyone else think its well out or are the readings ok?
    should I buy new injectors?
    27,099
    Search the forum for diesel purge, try this 1st.
    Aug 2010
    160
    tried it twice 2 litres nigel I have tried diesel purge, forte injector cleaner and some new stuff called diesel rhino.
    only thing left I have not tried is injector loom and new injectors.
    just want to know if the injector reading I post above (not the large pic) is showing the injector or injectors faulty
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Only cylinder 4 looks out of spec, have you checked the cam lobe for wear or done a pressure test on that cylinder?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Aug 2010
    160
    No cam wear looked it over when replaced glowplugs and Tbh I have never heard of or seen a bkd with cam wear think it was fixed on these mk5 tdi engines.
    sorted the pic out now sorry about mess about not used to uploading photos
    tdi-man's Avatar
    Jul 2009
    1,612
    i would say get timing cam belt timing checked by some one that knows how to do it and also set the injector timing as well.
    mine use to say similair readings untill i get the timing set correct
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Aug 2010
    160
    Had all new came belt done and other belt been checked by darkside and local bag place did the work. Injector timing? How do you check that can you use vcds for that and is it the injector duration?
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,755
    this is the technique for an a4, i would imagine the a3 to be similar,
    . re adjusting the rocker arms!
    jack up the o/s/f wheel and put the car in 5/6 gear. turn the o/s/f wheel in a forwards direction to turn the engine over and watch the each rocker arm "come on cam" when no.1 is at the peak of the cam lobe, adjust the 6mm allen key. wind it all the way down till you feel resistance, then back it off 270 degrees (3/4 of a turn). tighten up the 18mm nut.
    turn the wheel/engine again, you won't need to turn it much til no.3 is on cam. do this one in the same way.
    then no.4,
    and then no.2.
    done. stick the rocker cover on. (you shouldnt need to change the gasket as they are rubber reusable things, just give it a wipe down to get excess oil off it.).
    tdi-man's Avatar
    Jul 2009
    1,612
    i would go back to darkside and get them to do the injector timing as well
    Quote Originally Posted by bigal23 View Post
    max69vk's Avatar
    Apr 2012
    745
    Cylinder 4 is the dodgy one, its leaking so needs to dump extra fuel in to combust (due to a cylinder leak), cylinder 2 is running lean to try & compensate for it & will be ok.
    At a guess one of the injector seals has twisted when it was fitted & is now leaking, or worse case you've got the same problem that I had where the injector wasn't fitted properly & has damaged the head where the injector sits. Try doing a compression test on each of the cylinders & Im willing to bet it will show a compression leak on No.4 .
    Aug 2010
    160
    If the timing is ok would the only choice be new or refurbed injectors?
    max69vk's Avatar
    Apr 2012
    745
    Do a compression test, hopefully the injectors are fine & you'll get away with just fitting a new seal kit.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    They are pretty bad. Would suggest cam timing and injector clearance check.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Aug 2010
    160
    Been offered some new injectors with fully tested and flow sheets for a great price should I just get them and get a good deal while on offer
    tdi-man's Avatar
    Jul 2009
    1,612
    how much
    Aug 2010
    160
    400
    tdi-man's Avatar
    Jul 2009
    1,612
    waste of £400 if u ask me.
    plus u need new seals at about £20 an injector
    and new injector bolts
    Aug 2010
    160
    Any guide on how to check these?
    max69vk's Avatar
    Apr 2012
    745
    Aug 2010
    160
    Quote Originally Posted by max69vk View Post
    thank you for the link its great info there
    anyone have an idea screen shot or something that can tell what the injection quantity deviation would/should look like on new injectors?
    max69vk's Avatar
    Apr 2012
    745
    Bottom row on the screen shot below...
    Aug 2010
    160
    these readings are when the car is up to temperature would they change much when the car is started cold?
    max69vk's Avatar
    Apr 2012
    745
    Not really, the injection volume would be increased as diesels need more fuel when cold, but the balance would still be out of whack.
    Aug 2010
    160
    what would or could happen if an injector totally fails?
    Aug 2010
    160
    so now pulling off is very juddery like its not getting enough fuel and am having to reore to pull off is this injector or just the clutch?
    bloody car
    27,099
    TBH if its clutch, then its expected at some point as the 8P manuals do suffer from clutch wear, especially with a stage 2 turbo with loads of torque.
  28. #27
    Mar 2013
    44
    Replace the temperature sensor! I have the same sort of thing on mine atm! Don't rely on vcds its just an indicator and is hardly ever right! If the injector was leaking or fault it would go into limp mode extremely quickly! You wudnt be still driving it normally! I know this because my mechanic had a 2.0 tdi pd140 like mine, his injector went and he didn't even have time to notice the extra smoke, just went straight in to limp! I'm fitting a temperature sensor in mine tomorrow and wil let you know how I get on!
  29. #28
    Aug 2010
    160
    Yes please let me know.
    Still getting shocking mpg drive normal it's 28-30 drive very slow and gently then I saw 38 other day this needs curing as its costing in fuel now to much, still don't know if I should just replace all injectors and loom
    plus getting glow plug 3 fault these where replaced last month so carnt be a bad plug
  30. #29
    Aug 2010
    160
    Nigel it's not been mapped with loads of torque it's almost like standard Adam had amdjust map in the turbo to run smooth it's only running 150bhp roughly
  31. #30
    Mar 2013
    44
    Just spoken to another friend and he said 9 times out of 10 its the air flow sensor! because it works out the air flow and how much fuel to chuck in! Apparantly they should be changed every 50000!
  32. #31
    Aug 2010
    160
    so I had a play tonight with vagcom and altered my idle from 840rpm to 820 800 and 777. injection quatity changes with all of them but mainly with 777 (any lower car would jolt) at 777rpm it felt so smooth no vibrations or anything so quiet was great and injection quatity looked a lot beter all readings around 0.45-0.35-0.00-0.79 still injector 4 seems out but when put back to 840rpm the returned to a lot higher quatity they where 0.94-0.71-0.21-1.86 at one point inectors 1,2 and 4 where over 1+.
    is this normal as am confused that its so much better at low rpm but when back to stock seems so out of spec.
    could not keep the rpms at 777 as when pulling away the car juddered and needed more gas
    still unsure if I should get these injectors replaced am running out of ideas I have tried everything only thing I can think of
    tried the maf cleaned it with electrical cleaner spray to see if anything improved the car did for 5 min feel more responsive then went back to normal but it was nothing that was wow its fixed it proberly all in my head after I cleaned it
  33. #32
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    So if you have a problem with an injector how much out will it be compared to the others?
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
  1. Replies: 10
    Last Post: 4th July 2012, 00:49
  2. HELP WITH INJECTOR READ OUTS PLEASE
    By chrisk1700 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th April 2012, 17:41
  3. An interesting read....
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2003, 12:10
