EM TuningChris Nott
    Oct 2012
    26
    Rear Wiper Motor......
    Howdo!
    Had an issue with the rear wiper on my 2007 A3, wiper blade went past the window and rested on the paint work. On inspection the inner gear section had worn allowing excessive movement. So got myself a replacement of e-bay and cured the excessive movement However the bloody thing leaks! Sent a message to the seller, still awaiting a response. Is the gasket available for these?? Wondering if I could salvage the unit???? I have seen the repair kits but just need the gasket - or has anyone had any success with liquid gasket??
    Cheers Pablo
    27,099
    Was it a new wiper motor or used?
    Oct 2012
    26
    2nd hand unit of e-bay.
    27,099
    Just buy a new one, saves all the hassle later doesn't it, as you'll just be wasting so much time when the fix is fairly simple.
    Oct 2012
    26
    Hopefully the seller will refund and then it will be a new replacement.
  1. Removing rear wiper motor/arm etc
    By S3IZZO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2012, 20:54
  2. 1996 A4 Avant (B5) Rear Wiper Motor
    By CD8535 in forum The Welcome Section
    Last Post: 4th August 2006, 07:56
  3. Is there more than 1 type of rear wiper motor?
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2006, 10:21
  4. Rear Wiper Motor
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2006, 23:47
  5. Anyone replaced rear wiper motor?
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2005, 12:39
