Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    bug
    Jan 2012
    71
    ABS FAULT - 01316 PLEASE HELP
    Evening Chaps!
    Still got my ABS fault and wondered if anyone could please help me.....
    Had the car code read and the faults being brought up are:
    01316 - ABS Control Module No Signal/Communication
    00778 - Steering Angle Sensor (G85) No Plausible Signal
    3803 - Steering Angle Sensor for Steering Aid
    I've been told the steering angle sensor fault is as a result of the ABS fault. So I need to fix the ABS fault first.
    Looking on Ross Tech it says the following:
    01316 - ABS Control Module: No Signal/Communication
    Possible Causes
    • Wiring/Connector(s) from/to ABS Control Module faulty
    • Fault(s) stored in ABS Control Module
    Possible Solutions
    • Check Wiring/Connector(s) from/to ABS Control Module
    • Check Measuring Value Blocks (MVB)
      • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
    So it seems I need to look at the wiring connector onto the ABS pump?
    If anyone has experienced this fault or can help me at all it would be much appreciated
    Thanks all,
    Christian
    27,089
    Fuse?
    bug
    Jan 2012
    71
    Hi NHN,
    Check the two fuses in the engine bay fuse box, both are fine. Used a scotch pad to remove any corrosion to make sure the connection is good.
    Any ideas how you remove the connector block from the ABS pump NHN?
    27,089
    Yeah the top of the connector actually pulls upwards to release a locking/latch piece, so the connector itself can slide out sideways.
    bug
    Jan 2012
    71
    Ah lovely job, thats just what I wanted to know! Thank you!
    Once the connector is free do you recommend I check all the pins on the connector block? Is there anywhere else where its worth looking other than the connector block?
    27,089
    Well check with a multimeter the -/+ to make sure this at least works.
    bug
    Jan 2012
    71
    Will do NHN, I'll report back with my findings. Praying it isn't going to be a new
    bug
    Jan 2012
    71
    Will do NHN, I'll report back with my findings. Praying it isn't going to be a new ABS pump!
    Jan 2013
    Wiltshrie
    85
    I had a similar problem with a previous car, and spend a fortune, I had 2 new wheel bearings, 2 new abs sensors, sent my abs control module away to be checked repaired and still had a problem it turned out to be the wheel bearing I put in we're faulty as tha abs rings weren't correct from manufactures, I had the no communication fault code, mine would drive to start off with but then ESP would kick in and I wouldn't be able to accelerate unless I turned ESP off
    of
    hope this helps
    bug
    Jan 2012
    71
    Hi Craig, thanks for your input! Will check over all of the sensors etc before pulling my ECU out!
    Going to have a nose tomorrow, try and figure whats going on....
    bug
    Jan 2012
    71
    Checked over the car the other day, looking at the wheel bearings and the connector block onto the abs pump. All seems to be well, cleaned contacts on each abs sensor and checked there was power to and the contacts were clean on the connector block to the abs pump.
    Going to take the pump off on Monday and ship it off for testing.
  1. ABS Fault can anyone help
    By DenCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2011, 17:44
  2. fault code!! please help
    By spencerdale in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2010, 10:00
  3. Fault code. Please help!
    By mark_sarah in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 22:16
  4. Issues with a3 tdi sportback..........fault codes......please help!
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th January 2010, 22:59
