JMB RetrofitsAH Fabrications
Results 1 to 16 of 16
    tdi-man's Avatar
    Jul 2009
    1,612
    NEW BKD ENGINE NEEDED
    after i good place to surply and fit a recon engine 2.0 TDI 140 BKD
    any body ?
    thanks
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,219
    hey mate have a look here
    2.0 bkd | eBay
    you could always source an engine from breakers and get a mechanic to fit?!
    tdi-man's Avatar
    Jul 2009
    1,612
    thanks has anybody used these guys before as thinking of a complete recon engine of them ?
    AUDI ENGINE AUDI RECONDITIONED GEARBOX AUDI ENGINES AUDI ENGINE PARTS AUDI CHEAP ENGINES GEARBOXES FOR SALE
    May 2009
    West Yorkshire
    1,634
    Has it gone pop?
    Audi A3 2.0L TDI S-Line Sportback
    tdi-man's Avatar
    Jul 2009
    1,612
    LOL
    no its all good apart from it smokes a bit when u been on a run and leave it for a while and start it again.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    That's what mine does too occasionally.
    VCDS USER
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by tdi-man View Post
    LOL
    I think you'll find that it's soot blowing out, not smoke ! They all do it eventually but it doesn't signify a knackered engine !
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Get your egr valve checked and cleaned, its the usual culprite.
    tdi-man's Avatar
    Jul 2009
    1,612
    after speaking to loads of people im thinking of letting a local engine rebuild company remove my head and recon it and also recon the block while still in car as its not needed to be removed.
    do pistons need to be rebored and oversized if car has done 200,000 milles with full long life history as u cant tell untill remove head but alot of people so NO ????
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    New piston rings and de-glaze the cylinders would be advisable if your going to strip it down that much
    Shouldn't need to 'bore-out' them
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    tdi-man's Avatar
    Jul 2009
    1,612
    great thanks thats what ive been told
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    So has your BKD done 200k? There is hope for mine yet! (119k & just stage 1 map with EGR delete & also hot start fix map)
    shady-ninja's Avatar
    857
    im sure you can do better than £1750.
    shop arond to bypass the middle men
    and get your engine rebuilt.
    but you havent told us any thing
    about the milage of your car.
    Feb 2013
    10
    Get the 170bhp version fitted
    tdi-man's Avatar
    Jul 2009
    1,612
    yes m8 going to local engine rebuild firm they will do mine for 500-600 plus vat plus my m8 needs to take head of and use his ramps
    857
    not worth it as the ECU and other things have to changed.
    just get someone to rebuild the engine.
    Quote Originally Posted by JACK-TDI View Post
  1. New on here.. need help with engine ECU
    By scottyaudi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 13:22
  2. Help, I need a new AMK engine
    By Wingnut Express in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2008, 13:19
  3. Want to chip new S3 but need help....
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2004, 13:13
  4. A4 1.8 V5 engine needed
    By dsl1975 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2004, 18:31
  5. New User - help needed
    By markt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2003, 13:12
