EM TuningChris Nott
Results 1 to 29 of 29
    Jan 2013
    101
    S3 2010 S-Tronic with turbo lag when changing gear?
    First of all i'm new to this forum so hello everyone!
    I've found a 2010 S3 with S-tronic I really like but when I was out on the test drive I noticed when changing gear there was quite a bit of lag. Best way I can explain it is flat out in 3rd the gearbox changed to 4th and it took about half a second for the turbo to kick in again. Surely at 5k rpm the spool should be nearly instant with that load? I've watched a few youtube videos and it seems instant.
    The dealer says they will fix it but has anyone heard of this before or got any ideas what it could be?
    Thanks, Oli
    26,721
    Welcome Oli
    As long as dealer will warranty it, to fix aswell, then I would seriously consider it, also there are gearbox maps you can have potentially that can liven things up along with an engine remap, which may help resolve the issue if they find no problems, anyway stipulate, should you purchase, it must be resolved or car comes back etc.
    Jan 2013
    101
    Welcome Oli
    Thanks for the quick reply, they have said they will fix it but I am just concerned as dealers seem to say anything to get your money off you. I was hoping someone might of come across it before and I could point the engineers in the right direction. Other than being a boost leak or stuck turbo vane I can't find anything else on this forum.
    IceHanger's Avatar
    Dec 2011
    West Mids/North Worcs
    289
    Mine does this but at the top end of the rev range in manual mode and the DSG has upshifted itself, I did some logs and came to the conclusion I was hitting a stage one limiter slightly or run out of boost. Audi also suggested the same.
    Hopefully when I get round to mapping, it will cure it.
    The rest of teh rev ranges/changes are fine.
    Have you tried it in Manual or sport?
    IceHanger
    2011 S3 8P 5DR Black edition,
    2013 TT TDi BE with lots of toys
    Previous Vehicles:
    Audi S4 B6 4DR Big fuel bill edition
    Audi TT TDi S-line Quattro
    Skoda Octavia 4x4 Turbo,
    Skoda Octavia VRS Estate,
    Vauxhall VX220 Turbo,
    MGF VVC,
    Vauxhall Astra GSi,
    Alfa 33 Cloverleaf,
    Tons of Minis
    26,721
    Quote Originally Posted by OliS3 View Post
    Then as I advised, get it stipulated you have noted this issue & they are to resolve/fully investigate this & should the fault worsen, then they would be required to fix it at such time, get in writing.
    jaydav2306's Avatar
    Cant say that I have had this with mine, by fixing it I assume they would mean a new mechatronic unit, I would try and find one without the lag or test drive another see if it's normal
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    Jan 2013
    101
    Quote Originally Posted by IceHanger View Post
    I doubt it is the limiter as it is in the next gear it loses the boost and pulls fine to redline. I'll try and speak to an engineer and see what they have to say about it.
    IceHanger's Avatar
    Dec 2011
    289
    I meant you just brush the limiter in one gear as it changes up, so the engine has cut power briefly and has to build it again so it would be felt in the next gear.
    It sounds like thats not your problem anyway.
    IceHanger
    Previous Vehicles:
    MGF VVC,
    Vauxhall Astra GSi,
    Alfa 33 Cloverleaf,
    Tons of Minis
    Jan 2013
    101
    No that does sound similar. I only noticed it at the end of the test drive so I'd need to drive it again test it properly.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    Power should be completely smooth if accelerating flat out. The only delay that can sometimes occur is if you shift to a gear the box isn't expecting, and you get a little lag. I've also come across remapped cars which haven't been done right which have this issue, but I doubt that's the case here. Suggest you drive it again to make sure, and drive another to compare it to.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jan 2013
    101
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Rick
    I thought as much, from what I've read the DSG box constantly transmits power to the wheels during a gear change so the load to the engine should also be constant meaning the turbo should stay spooled.
    I can't think what would cause it though? At first I thought boost leak but now i'm thinking more a sensor error?
    Jan 2012
    367
    First port of call would be to take the DV apart and check it for leaks / splits (depending on the version you have fitted). Has the car been mapped by a previous owner that you are aware of, as there are known issues with later s-tronic cars and lag between gear changes with some remaps.
    Jan 2013
    101
    Quote Originally Posted by nluk100 View Post
    As far as I know the car hasn't been remapped.
    Just spoke to the tech and they are saying that it is normal with the 2L turbo and S-tronic combo I've asked him to drive it and explained the problem again and he is going to call me back later.
    I guess until they admit there is a problem i'm going to walk away which is a real shame as the car, colour and spec is perfect
    Jan 2013
    101
    The head tech has drove it and he agreed there is an issue so they are going to look into it tomorrow and will get it sorted so I can buy the car.
    Can't wait
    Jan 2012
    Stockport, Cheshire
    683
    It will be interesting to see what happens. Could be an issue with the mechatronics unit.
    Rick
    26,721
    Not heard of this on a 2010 yet, but be interested to know.
    Jan 2013
    101
    I'll keep you all informed. I've just read up on the mechatronics unit and I don't think it was that as the changes seemed fine. The issue was more with boost coming in.
    I'll see what they say today and I can always test drive it again now I know more about it i'll have an idea on what to look for.
    jaydav2306's Avatar
    Sounds more like a DV issue
    Jan 2013
    101
    Quote Originally Posted by jaydav2306 View Post
    Just causing a boost leak?
    jaydav2306's Avatar
    Yeah sort of, the issue you described I sort of had, around 4-5K flat out it would just stop, then go again, I changed the DV to a revision D part from Audi and havent had the issue since, now my car is a late 2009, finished being built 30th June 2009 I believe and the car you drove a 10 plate so it could be a similar issue.
    Jan 2013
    101
    Thanks for the update, I wish I could drive it again as I didn't force it into a gear and run it from low revs to redline. I should hopefully have an update from them later on though. I think it is only a small issue but i'm not committing to spending 20k without it being perfect.
    Jan 2012
    367
    A faulty DV will cause the turbo to stall between shifts, hence appear as lag.
    Jan 2013
    101
    Thanks, it does make sense. Should the DV make any noise as standard as I never heard anything on the test drive? I know they normally recirculate as standard but in my EVO i could still hear some noise.
    Jan 2013
    101
    Also is there any easy way to test it is working correctly?
    jaydav2306's Avatar
    A faulty DV will flutter so its an obvious stalling noise, with the windows down and my new DV on after 3K revs I just get a really nice pitch constant whistle and you can hear it on constant boost, no flutter at all, it's an awesome sound, even nicer with the S-Tronic as you get the exhaust burp when you change gears I love mine
    Jan 2013
    101
    I can't say I noticed a flutter noise but that doesn't mean there wasn't one. I did notice the exhaust burp though which I loved
  28. #27
    Jan 2013
    101
    I've spoken to them again and the tech said he drove another S3 T-tronic and he could see what I meant (Worrying as I noticed it and I've never driven any kind of S3 before) He said he reset the gearbox learning memory and it has solved the problem. I need to get over there to drive it again but could that really solve it?
    Thanks, Oli
  29. #28
    JS3
    Oct 2011
    209
    I have a 2010 s-tronic, cant say I have noticed this lag, it is very smooth under acceleration and I have the rev D valve I believe. Next time you test drive can you check the valve quickly? I believe (from memory) its a quick check under the bonnet but do a search on here and it should tell you where to find it. Somebody may correct me though!
    2010 S3, Sprint Blue, S-Tronic, RNSE, Cruise Control, Interior Light Pack, Upgraded LED Interior Bulbs, Heated Seats, Hill Hold, Boot Buddy, Fog Turn Lights, Revo Stage 1, De-Wipered
  30. #29
    Jan 2013
    101
    Quote Originally Posted by JS3 View Post
    I drove it again today and the conditions weren't ideal but from what I could tell the issue had been resolved or reduced a lot.
    I agreed to buy the car on the basis I had a letter from the dealership showing I had reported the issue and that if it hadn't been resolved they would resolve it under warranty in a reasonable time. Hope I've done the right thing.
  1. Possible cure for the annoying S3 over revving when changing gear
    By Crazypete00 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2010, 22:12
  2. Clunking Noise When Changing Gears
    By JUX in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th May 2008, 21:53
  3. stalling when changing gears on S3
    By froggy72 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2006, 15:04
  4. continues to rev when changing gear?
    By jaysback in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2006, 20:29
  5. Over Revving when changing gear - Fixed!
    By h3msy in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 13:21
