Results 1 to 12 of 12
    Jan 2013
    Surrey
    2.0 TDI Quattro 288mm to 312mm discs help needed.
    Hi all,
    I know this question has been asked many times before and having researched it I am of the understanding that all that is needed for the mod is the bigger discs and bigger caliper carriers.
    However after buying a set of 312mm discs and new ceramic pads, I bought a pair of 312mm spec caliper carriers on eBay and they are the right height to accommodate the bigger disc and to bolt to the caliper but the bolt holes are in the wrong place for mounting it to the stub.
    So what I'm asking is, 1) what vehicles have the caliper carrier that I need fitted and 2) anyone have any part numbers that may be of use.
    Thanks for your help
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Hi, welcome to audi-sport.net. Any pics of the car? Where are you located? Enjoy the forum. x
    tdi-man's Avatar
    Jul 2009
    1,612
    if yours is a Quattro you my need Quattro carriers but not sure.
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    I thought that the front discs were already 312's? Mine where the same as a Golf GTI as I sold them to a mate who wanted now ones when I udgraded to an S3 setup and they fit straight on.
    You have the 170 Quattro?
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    27,126
    No there are 280, 288, 312 & 345 front disc sizes & I've seen this before tbh, you'd need to change the bearing housing clamp part, just grab a vin or plate of someone who has 312's & get part number of there original factory spec.
    Jan 2013
    Surrey
    Sandra - hi I'm from Surrey, I'll post some pics once I am on my. PCDaggerit - it's a 140 Quattro and was/is fitted with 288mm at the front and solid discs ant the back. NHN - so does the baring housing clamp differ for 288 and 312 discs was hoping I just needed a taller caliper carrier. Are the caliper carriers different for the 8L? Wondering if that's why the ones I got of eBay are different to mine. Please excuse the formatting I'm doing this on my iPad :-)
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    I've never heard of a 140 quattro! Haha, that'll be why I was confused by the brake size. I thought that the diesel quattro cars were only availible with the 170 engine and therefore the 312mm brakes, sorry.
    Jan 2013
    Surrey
    this is a picture of the caliper carrier i bought off ebay. can anyone identify what its designed to fit???
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    There should be a part number on it somewhere, it should be in the format XXX-XXX-XXX X (the last 'X' is usually a letter if its included).
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    27,126
    Ye just wing us the part number, may need to rub it down a little to find it, but that would allow us to check which cars it fits.
    Jan 2013
    Surrey
    Right i finally got a pair of caliper carriers that fit and worked out that the original pair i bought were for a 8L chassis after comparing them with a mates S3, so my mistake on that one.
    Heres a couple of pics of the old 288mm brakes and the new 312mm grooved discs with EBC redstuff cermaic pads fitted.
    I'm going to paint the calipers red once the weather is a bit better.
    tdi-man's Avatar
    Jul 2009
    1,612
    have u still got the 8L ones ?
  1. 2007 a3 quattro 170 tdi high idle loss of power help needed
    By gixer600 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2011, 15:37
  2. A4 1.8T Avant Limited Edition B6 2004 (163PS) - 288mm or 312mm Brake Discs ?
    By sniffy_smiffy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th July 2010, 21:44
  3. 288mm-312mm disc conversion kit.
    By AndymacA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2009, 21:01
  4. 312mm discs on a 288mm disced car - Advice needed please
    Last Post: 16th December 2008, 21:16
  5. TDI quattro brakes - disc and pad upgrade
    By TDI_Boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2006, 21:50
