Chris NottMonster Motorsport
    TDI140's Avatar
    May 2011
    1,364
    Brembo pads not very good ?? Used on gti edition 30 set up
    I have golf gti edition front brake set up on my car and standard 2.0tdi rear break set up, and all round brembo pads replaced couple weeks ago, ive noticed the brakes are good but if i brake hard the brake pedal becomes hard and brakes dont work aswel and also when i park up and get out the car i can smell the pads as if they have been set on fire, does this occur with anyone else on the forum with brembo pads ?????
    thanks
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    27,129
    Did you use the brakes extreme from day one of the new pads being fitted or gave them some sensible braking to bed in well.
    TDI140's Avatar
    May 2011
    1,364
    i allowed the pads to embed with the discs braking is fine when driving slow or applying the brakes frequently but if they are used alot around country roads and such they tend to get really hot and i can smell them as if the pad as if it has crumbles away but on 2 occasions ive taken my wheels off to check and the pads look perfectly normal and same with the discs they have no grooves in, could it be that it happens due to them being performance bads they need to be warm to work ??
    jimojameso's Avatar
    Sep 2012
    Surrey
    214
    I had a mk5 gti and always thought the brakes were a bit poop to be honest
    2010 TT RS - Sepang Blue - MRC 420BHP, 600NM
    2010 Stage 2+ S-Tronic S3 BE SB in Ibis White!! ....... SOLD
    27,129
    I would contact supplier & ask if it needs a better pad/disc match up mate.
    TDI140's Avatar
    May 2011
    1,364
    next time i will definitely be buying OEM pads and discs i always buy OEM
  1. Anyone used brembo pads on there s3 stock setup? rate or slate?
    By KB in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2010, 21:39
  2. S3 Heater is not very good?
    By skelters in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2008, 18:34
  3. Quick Joke (not very good)
    By imported_Wicked666 in forum General Chat
    Last Post: 2nd October 2005, 17:57
  4. Replies: 4
    Last Post: 24th April 2005, 17:35
  5. I raced a APR S3 and was not very impressed
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2003, 11:48
