Volks AutosSky Insurance
Results 1 to 12 of 12
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    corrct camber/alignment ? A3 SPORTBACK 5 DOOR..TDI
    just had camber/alignment checked by kwik fit...........these are the results
    car is a sprt model,lowered exactly 23mm on springs (before and after check showed lowering by 23mm using 30mm springs)
    Do these need sorting out? kwik fit said yes,but a worker there who carried out the check said they are ok to be honest(but that was on the hush hush)
    Are they out alot ?
    Full leather/19"wheels/cruise/
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    887
    To be honest, I think that the fact that the wheels don't have any consistency in the camber lowering has produced you may have something else wrong?
    In the scheme of things the values aren't massively out but I'd be making sure that the left and right wheels are the same to be honest otherwise you can get some strange handling characteristics. And uneven tyre wear.
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    Are we talking front or rear wheels? the car handles good but ive noticed uneven tyre wear at the FRONT ,the back tyres had changed 2 weeks ago,so cant remember the ones that came off or what they were like,car drives straight.
    Quote Originally Posted by Daggerit View Post
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    887
    From that printout I'd say both!
    Looks to me if anything it would pull very slightly to the right. If you can then I'd get it sorted out but that said, I don't think there's camber adjustment in the front wheels? That's why I'm thinking there may be an underlying issue?
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    what i meant to say was, ive not noticed uneven tyre wear in previous, car dont pull at all drives 100% straight,only reason i had camber check was cuz i had complete rear axle replaced at rear.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    887
    Strange...
    Back to the original question though, you could get away with that but I'd be getting the alignment done just in case I think.
    Also, why did you have the entire rear axle replaced?
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    some dum cow hit me,only kinking the wheel arch,but breaking half my wheel,the wheel to all the impact,the cradle/axle was kinked so replaced it all............do you think kwik fit may have give/done wrong readings?
    Strange...
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,005
    Don't bother with Kwik Fit mate, they don't know their arse from their elbow half the time. Take it to somewhere with a Hunters alignment system.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    887
    Quote Originally Posted by leeds2592 View Post
    I'd totally agree with the Kwik Fit comment, just a bunch of stealing tw*ts!
    Did the repair company check the chassis wasn't damaged or anything? Wondering if maybe it was slightly twisted or something which could cause the excess camber. Since camber rates are fixed for McPherson setups I can't think if much else... :/
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    il find out then,thanks,are they out alot? dont know how they say the fronts out,i had 4 wheel alignment done by ats around 7 month ago and car drives spot on,just having a replacement axle thort id get it checked.
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    no......no damage anywhere apart from rear wheel,and slight kink on cradle/axle that we had to look for,but as i wanted it 100% decided to replace complete rear
  1. Sportback Door Trim
    By mattyboy84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th June 2011, 13:41
  2. 2008 A3 Sportback door cards
    By welshwoody in forum For Sale/Wanted - Audi Parts
    Last Post: 10th May 2011, 14:59
  3. Replies: 1
    Last Post: 7th July 2010, 22:24
  4. a3 sportback door handles
    By mozza1202 in forum General Technical / How To
    Last Post: 5th May 2010, 23:35
  5. A3 Sportback 2L TDI DPF option code?
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2008, 00:14
