Monster MotorsportChris Nott
Results 1 to 10 of 10
    TimJK's Avatar
    May 2011
    Norwich, Norfolk, United Kingdom
    407
    S3 8P Release bearing
    been searching for uprated release bearings for audi S3 8P's does anyone make them? Putting in an uprated clutch so wandered if there is an uprated bearing also.
    Thanks.
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,548
    Hi tim ,u just need a oem standard release bearing from audi and new flywheel bolts
    TimJK's Avatar
    May 2011
    407
    If it's leaking I will replace mine, but I wandered if there was an Uprated version anywhere out there to save failure
    pinterovski's Avatar
    Oct 2010
    661
    Add pinterovski on Facebook
    Now in your S3 you probably have release bearing with plastic casing which is good
    but that's what you need now buddy! No more plastic
    Audi Vw VAG OEM Clutch release bearing 0A5141671F - FR&R Tuning| MAHA Dyno Rolling Road Tuning| Stage 1, 2 & 3 Engine Performance Upgrades - (Powered by CubeCart)
    Black roof,Tinted windows,Solar Orange Calipers,KW V3 Coilovers,
    HEKO Wind Deflectors,CAI ITG Maxogen,Non Res Supersprint Exhaust CB with custom Fi76mm DP,
    RevD with GFB DV+,Autotech HPFP,Custom SKN map Stage2,Forge ShortShifter,THS mounts,
    Twintercooler,Clutch is now on LOBA/SACHS!!!
    18 OZ Ultraleggera!
    365HP and 500NM of torque!
    TimJK's Avatar
    May 2011
    407
    That is oem it says and looks plastic?
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Yeah replace with OEM and is plastic - and easy part to fit but a basstard to get to!! Whole subframe, gearbox and clutch has to come out!
    Oct 2010
    661
    Tim make a call to FR&R,the last time i ordered clutch release bearing for my S3
    from them it was not plastic!
    18 OZ Ultraleggera!
    TimJK's Avatar
    May 2011
    407
    That bearing is the same as original. Part numbers match
    Oct 2010
    661
    Quote Originally Posted by TimJK View Post
    I wish i'd took some photos of the old one when i fitted the clutch and new release bearing
    to my car! The old one was all plastic housing and the new one is made from
    sime kind of a magnesium casing i believe. Yes the part number is the same but you can still
    get the ****ty plastic one
    18 OZ Ultraleggera!
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    I have pictures - hold on!
  1. LUK DMF and Release Bearing for 2008 S3 8P1 (Deliver to Aus)
    By NCRAW in forum For Sale/Wanted - Audi Parts
    Last Post: 20th April 2012, 05:09
  2. Buying LUK DMF/Release Bearing/Bolts from UK. Where From to Ship O/S?
    By NCRAW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th April 2012, 03:19
  3. Clutch Release Bearing? And Failed MOT!
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2010, 18:54
  4. Clutch release bearing
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th December 2009, 20:31
  5. Slave or master cylinder or even release bearing?
    By sonij70 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2009, 19:42
