Volks AutosMonster Motorsport
Results 1 to 15 of 15
    Ben S3 8P3's Avatar
    Jul 2012
    Bury//Manchester//Leeds
    313
    Is my RNS-E a retro fit?
    Is there a simple way to tell if the RNS-E unit was a factory or retro fit? Because the AUX facility doesn't work and I don't have amazing radio reception.
    If it is retro-fit how do I get the AUX to work?
    Thanks, Sorry for being a complete Audi noob
    Ben
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    If you have a RNSE and there is no sharkfin aerial on the roof then it is definitively a retrofit, as most people dont bother to put sharkfin as it involves drilling the roof. Another way is to pull out the unit and see if there is any adaptors converting the old connectors to rnse connector.
    Ron
    Audi A3 8P2 2.0Tfsi S-Line Special Edition Bluefin
    3dr Mauritius Blue || Full Leather|| BOSE || MFSW || Auto Lights/Wipers || Auto Dim Rearview Mirror || Heated Mirrors
    Mods: S3 Aluminium Pedals || S3 Vents || 2010 RNSE || OEM Bluetooth || Dension Gateway 100 || MY09 Rear Lights || Single Xenon Headlights
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Have a look in your service manual or in the spare wheel location in the boot where you will find a sticker with lots of PR options codes codes on (3 characters).
    Then tap them all in to here- VW Group Option Codes Decoder
    Not sure which one RNS-e is though.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Ben S3 8P3's Avatar
    Jul 2012
    313
    Quote Originally Posted by BlueSpark View Post
    I do not have the sharkfin on my roof. So thanks for very quickly solving that one for me.
    Is there a way to improve reception / sort my AUX issue. Everything else works fine eg, satnav, cd player etc
    Jameze's Avatar
    James
    Jul 2011
    Leeds
    505
    The radio reception seems to suggest it might be - I believe the RNS-E uses a different antenna system to the other head units. Although the old one will work, sometimes it doesn't work great for people (bad reception etc). I've upgraded from a Symphony II+ to an RNS-E without bothering to upgrade the antenna (to save some money) and it's been fine for me. It's hit and miss with some people.
    One thing you could do is check your vehicle identification sticker (should be one in your boot and one in the front of your service book) and run the codes through this website...
    That should tell you what your car came out of the factory with.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Sounds like you need a new radio antenna which is located in the boot lid, it's not cheap. What year is your A3?
    Jameze's Avatar
    James
    Jul 2011
    Leeds
    505
    Quote Originally Posted by A3Kent View Post
    Too quick for me!
    Ben S3 8P3's Avatar
    Jul 2012
    313
    Its a 59 plate.
    Oh well, im not too bothered about the radio, its not bad when the volume is low, but then a bit distorted when you turn it up.
    I just wanted to get to the bottom it. Is the AUX also expensive to sort?
    Thanks very much for everyone help and quick replies !
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Don't know too much about the AUX but this may help - rnseauxin - Audi Retrofit
    And also, as yours is a 59 plate it has the antenna in that's not as good as the older models unfortunately. Mines an 09 plate and chose to have mine changed when I had my RNS-E put in by Nigel.
    Feb 2008
    Europe
    231
    Navigation code = 7Q2
    a3_sline_tdi's Avatar
    Aug 2009
    894
    Auxiliary is only 3 wires and as its a retrofit they will still be in the quad lock connectors, so they need to be removed and you will need to buy a multimedia adapter from audi for like £3 and move them into there. You need to get a photo of a concert/symphony sticker on the top showing the connections and then look on your RNSE and see the positions were they need to go in on the new 32 pin multimedia plug. Connections will read LEFT, RIGHT and GROUND.
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    my rns is not a retrofit and it does have **** reception
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    I have a shark fin in my S3 56Plate... But no RNSE... Does that mean it should have one?
    Aug 2009
    894
    This will be for your Bluetooth/phone prep as its used for that as well as sat nav
    Current
    previous
    JS3
    Oct 2011
    209
    I heard the four vertical lines on the rear window (like the heater elements but up and down) are the radio antenna? Could be wrong though.
    2010 S3, Sprint Blue, S-Tronic, RNSE, Cruise Control, Interior Light Pack, Upgraded LED Interior Bulbs, Heated Seats, Hill Hold, Boot Buddy, Fog Turn Lights, Revo Stage 1, De-Wipered
  1. Audi RNS-E Satnav Retro fit in an Audi A4 B6
    By seanr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2012, 13:45
  2. Retro Fitting the RNS-E head unit & DIS Integration
    By timjhoward in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th October 2007, 21:44
  3. RNS-E retro fit question (My car is in bits!!)
    By danc in forum In-Car Entertainment
    Last Post: 14th July 2007, 11:18
  4. Retro fit the RNS-E system into the A4
    By beerglass in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th January 2007, 16:01
  5. RNS-E retro fit, pics
    By imported_G4JSG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2006, 08:48
