Volks AutosChris Nott
Results 1 to 13 of 13
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    New steering module, ESP and power steering lights on.
    After a few problems I finally got my MFSW to work after installing a new steering ECU (8P0 953 549 F). Now it's thrown up the ESP and power steering warning lights along with having no power steering. I've had the power steering problem after changing the wheel before and it was solved by turning the wheel all the way to the left then all the way to the right, but this isn't doing it this time! I've took it for a drive to see if they would sort them self out but no luck. I've also tried disconnecting and reconnecting the battery. Is there some coding that needs to be done in Vagcom as its a new ECU?
    Aug 2010
    1,540
    if its new it'll require coding in to tell it what car its fitted to (options wise) and to initialise.
    yep, turning fully to the left then all the way to the right and back to center, not too fast and not too slowly, should then set up the power steering.
    a short straight ahead (above 12kph (at a guess?)) drive should set up the steering angle at 0 (esp light goes out).
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    Will I need to code it first before I can get the power steering and ESP back? Also do you have any useful links that explain how to code it properly? Thanks
    Aug 2010
    1,540
    not really any coding i do at work is usually thru guided functions on the vas 5052.
    you could plug the old ecu into the car.... read the coding off that..... then swap in the new one..... and input it manually into the new one? but as youve got a different steering wheel its probably not the same........
    couldnt you just have got the old ecu recoded to tell it it now has the multifunction steering wheel option??
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by murran View Post
    Only steering modules 8P0 version E and F can be coded for mfsw.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    If you have changed the steering control module then you will need to code the new module to suit your car and do a basic settings reset on your steering angle sensor and possibly on your abs module. I have had this many times when retro fitting these modules for mfsw and cruise
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,110
    As Ash mate, it is not just a case of turning wheel to reset, you need to do some basic settings with vcds. PM your email mate and I can send you a guide on how to do this.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    Ah I see, I've pm'd you my email
    Aug 2010
    1,540
    ah, i see.
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    All sorted, cheers bluequattro for your vagcom skills! Power steering has never felt so good!
    Aug 2008
    408
    You are v welcome matey
    Aug 2011
    24
    Quote Originally Posted by bluequattro View Post
    Hiya bud is ther any chance you could email me this guide.. Im havin the same problem, thanks
    jimcazz86
    May 2013
    manchester, uk
    6
    Hiya m8 is ther any chance you could email me this guide as iv put new speedo in started car but loads of faults come on so put old speedo bk in and now no power steering any idear m8???
  1. ESP and another warning light both on
    By mandyray in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th August 2011, 11:03
  2. Replies: 12
    Last Post: 5th January 2011, 17:19
  3. ESP and ABS Warning Lights
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd September 2010, 10:52
  4. Engine Mgt, ESP and Emissions control light on - help!!!
    By razza1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd August 2010, 11:55
  5. ESP and Battery Warning Lights
    By djcormie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2009, 14:46
