Hi Guys,
Had my audi a3 2.0tdi BKD 8p remapped yesterday and the car has been going great, more power, more response really happy with it. However i just wanted to hook the car up today to check for any faults just in case and i have found a few! im really worried that its related to the remap but im not sure. Here are the faults that where logged:
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0CDFN20D6
Coding: 0000072
Shop #: WSC 01286 386 08256
VCID: 27567E6AEF85
1 Fault Found:
16725 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 000 - - - Intermittent
Freeze Frame:
RPM: 336 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.34 V
Bin. Bits: 11000100
Idle Stabilization: 0.0°KW
(no units): 3.0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A70B71E0C37
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000388879
Coding: 03884F00A2141000000000000000000000
Shop #: WSC 00000 000 00000
VCID: 3B7EB21A030D
Part No: 8P2 955 119 C
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
6 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
01320 - Control Module for Climatronic (J255)
00483 - Control Module for Auxiliary Air Heater
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00466 - Control Module for Steering Column Electronics (J527)
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.10 1202
VCID: 2E588B4EC07F
2 Faults Found:
02441 - Yellow Malfunction Lamp in Instrument Cluster
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 7440 km
Temperature: 27.0°C
Voltage: 12.10 V
Voltage: 11.90 V
Freeze Frame:
Mileage: 7480 km
Temperature: 31.0°C
Voltage: 12.30 V
Voltage: 12.20 V
I have cleared all the faults and they havent come back but i havent taken it for a drive yet since i cleared them.
Should i be really worried? Are they all serious faults? Do you think they are related to the remap?
I would really appreciate some advice on this. Any help at all would be great!!
Chris
Coding: 0000072
VCID: 27567E6AEF85
1 Fault Found:
Freeze Frame:
RPM: 336 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.34 V
Bin. Bits: 11000100
(no units): 3.0
Coding: 0023174
VCID: 3A70B71E0C37
1 Fault Found:
VCID: 3B7EB21A030D
Coding: 16711696
Shop #: WSC 00000
6 Faults Found:
VCID: 2E588B4EC07F
2 Faults Found:
Freeze Frame:
Mileage: 7440 km
Temperature: 27.0°C
Voltage: 12.10 V
Voltage: 11.90 V
Freeze Frame:
Mileage: 7480 km
Temperature: 31.0°C
Voltage: 12.30 V
Voltage: 12.20 V
Chris
