Monster MotorsportChris Nott
    Pipsqueak's Avatar
    Jan 2012
    Glasgow
    117
    Constant beep noise from engine bay
    Good afternoon. I was out changing some headlight bulbs. I turned the ignition on but didn't start the engine. I noticed a constant beep coming from the engine bay near the radiator which lasts about 20 - 30 seconds then clicks off. Sounds like a quiet version of the warning beep in the cabin but that isn't where it was coming from as it kept going with the key out and doors shut and the car locked. Can anyone tell me what it is. Is it a relay, glow plug something else?? I'm totally foxed
    27,013
    If its what I think it is, its normal, ignore it.
    Feb 2012
    South Yorkshire
    29
    I have also noticed this in mine, however my mate said that this was nothing to worry about
    Pipsqueak's Avatar
    Jan 2012
    Glasgow
    117
    Thanks for the replies. That's what I get for going under the bonnet in the first place. I know plenty about problems with buildings but knowt about motors. Always willing to learn though! Cheers.
  1. Audi TT-S Engine cover on A3 09/10 Engine Bay?
    By xnox202 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2013, 20:11
  2. A6 hazard switch / relay constant ticking noise
    By Damianevs in forum General Technical / How To
    Last Post: 16th March 2011, 22:51
  3. warning beep noise but no display message
    By zeeeebo in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2011, 17:30
  4. Noise from engine bay of TDI...
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2007, 21:22
  5. ALARM SETTING AUDI TT BEEP BEEP
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th March 2007, 14:08
