Badger5JMB Retrofits
Results 1 to 18 of 18
    Jimmy1982's Avatar
    "No Skool Like Old Skool"
    Feb 2012
    Lancashire
    22
    Question Audi new owner - Advice needed
    Hello all,
    Im new to this forum and also new to Audi, I have currently just purchased a 2011 Audi A3 Black Edition and I'm after some help regarding the below:
    1) I am looking to upgrade the head unit in my car and really wanting to go with the RNS-E. My car currently has bluetooth which is running through the driver information system which is obviously separate from my current head unit and I don't want to loose this function. I have had a price off a chap on ebay for a RNS-E fitted and coded with a GPS module hidden in the dash for £999.99. The problem here is the cost and I will need to complete a very long drive to get to there garage. Can anyone advise of anyone selling one or know any contacts? Would it be worth buying one and getting someone to code it all in / fit? I'm pretty handy at fitting things myself so would give this ago. Just for info I currently have installed the double din Concert head unit. Would it also be worth considering a aftermarket head unit, if so would the bluetooth still work and also the steering wheel functions. Further advise on aftermarket head units will be grateful to.
    2) I'm also looking for a S3 full gear nob and gator (manual) including DIY guide
    3) S3 metal pedal set (manual) including DIY guide, do these just fit like the rubber ones apart from the accelerator pedal
    4) Any other nice touches any of you can recommend?
    Just for info I live in the Lancashire area and willing to travel.
    Thanks in advance for any help.
    Regards
    Jimmy
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Hi & welcome Jimmy,
    You can get the latest RNS-E fitted for much cheaper than that - check other Bay prices, being aware that many are cheap for a reason. Others on here can get legit units & fit them - they'll be around soon & will reply.
    There are also comprehensive guides on the forum showing how to install them, as they're such a popular mod. Just do a search.
    Other mods for your new car? Lots really - more power / lighting tweaks... For ideas, keep an eye out on the for sale thread at the top of the 8P threads page to get ideas for what people are doing / selling. There's all sorts.
    Enjoy the motor...
    123d MSport coupe from the company
    2007 S3 in sprint blue - gone!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,453
    Hi Jimmy, welcome to ASN. Have a look in the classified section for parts, sure one of the guys will be long shortly to advise you. Enjoy the forum.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Hi Jimmy,
    Welcome to the forum fella.
    Good choice about the RNS-e although some may talk you out of it as prefer after market for better functions. (Ash may be along soon, lol).
    you will not lose the function of your Bluetooth, if anything you will gain, as you will be able to get all your contacts, see missed, dialled calls, make calls all from the RNS-e.
    It is pretty straightforward to install the unit and put the gps on top of the glove box, or I am sure there is someone here near you that will fit and code for a few beer tokens! :-)
    A problem that you will occur though is the radio reception as it uses a different antenna module than the concert, symphony etc. You will get reception but may find it cuts out easily, so ideally you would want to upgrade, but the bad part is it can cost a couple hundred.
    There are a few people who can do this for you, the one nearest is probably Jonny (jb0o) who is in Hartlepool, or Nigel (NHN), he is in the south but does travel. Two great guys and you will not be disappointed.
    Good luck mate, and welcome once again.
    Jimmy1982's Avatar
    Feb 2012
    Lancashire
    22
    Quote Originally Posted by BigBird View Post
    Hi & welcome Jimmy,
    Enjoy the motor...
    Cheers for the reply BigBird,
    Was hoping that I could get the RNS-E fitted cheaper than that. Just want to get one off a trusted party and know that it will be fully working in every way it should be. I'm 99.9% sure I will prob be able to do the install myself but it will obviously require coding.
    Quote Originally Posted by Sandra View Post
    Hi Sandra, cheers for the reply. Don't worry I'm keeping my eyes open!
    Quote Originally Posted by Dannykn9 View Post
    Hi Jimmy,
    Cheers Dannykn9,
    I know people will have mixed views on the RNE-E, I just love the look of it installed. Not really seen any aftermarket ones that look as good! So will the RNS-E be able to view my contacts, missed calls, dialled etc. as standard as I'm sure i read somewhere that bluetooth was an optional extra if you want it to run through the RNS-E and if so you had to buy some extra bluetooth bits?
    Install / code sounds like a plan with payment of quite a few beer tokens! ;-)
    Im a bit concerned about the radio reception you have mentioned. When you say upgrade do you mean that it is quite costly as it will require the small standard "bee sting" antenna which cubs installed if factory installed? So will it not just use the antenna i already installed which is hidden somewhere on the car, or may be use an adapter?
    Once again cheers for these replies.
    Regards
    Jimmy
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,453
    Quote Originally Posted by Jimmy1982 View Post
    Hello all,
    Regards
    Jimmy
    Check this link out.
    http://www.audi-sport.net/vb/sale-wa...ml#post1506273
    Jimmy1982's Avatar
    Feb 2012
    Lancashire
    22
    Just read somewhere that to use the sat nav on the RSN-E you have to keep the sat nav disk in the DVD drive, is that right?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,453
    Will see if i can find out for you, but im pretty sure that is correct.
    347
    347's Avatar
    Sep 2006
    253
    this is correct , the dvd contains all the infomation for route guidance ,so the rns-e has to read from it to work . so the latest 2012 disc should have the up to date road changes on them .
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Yep, that is correct mate.
    To answer your questions in previous post, no extra wire is required for the Bluetooth, it should all be incorporated into your existing harness which plugs into the RNS-e.
    With regards to the radio reception, the actual modul is located in the boot or tailgate, can't quite remember. Your actual aerial is your tailgate window, but the wires go to this module.
    Some people don't bother to change because of the price and just live with the reception.
    Hopefully someone will be along soon who can explain it better.
    Sorry not to have been more on this one pal.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Fossie
    Rhubarb Triangle
    3,969
    Did you want something else in the DVD drive ?
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    The rns-e sat nav can be quite picky I have found. it won't let you enter a full postcode. and often the street you want it doesn't have. Sat nav wise the portable garmins and tom toms far exceed audis attempt. everything else isn't bad
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jimmy1982's Avatar
    Feb 2012
    Lancashire
    22
    Errrrrrm.......... a music CD ;-)
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    a CD? thats a bit old skool these days
    Fossie
    Rhubarb Triangle
    3,969
    The RNSe has two SD card slots behind the screen. Most people ditch the cd's and use these cards. (or an ipod !)
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,425
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    I'm selling my RNSe... Get in touch if you want more info.
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
    Jimmy1982's Avatar
    Feb 2012
    Lancashire
    22
    Quote Originally Posted by Cruiser89 View Post
    Hello, I'm interested in this.
    Please can you PM me the details / specs & condition and most important ££££. ;-)
    Jimmy1982's Avatar
    Feb 2012
    Lancashire
    22
    So is there a way to boost the antenna to improve the reception? Or will it be a full install to solve the reception issue?
  1. help needed! newbie audi owner!
    By rustynlc in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2011, 18:30
  2. New owner saying hi and a bit of advice needed
    By tedster in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th October 2009, 16:47
  3. New S3 owner - some issues - advice needed
    By pcmanning in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2009, 11:03
  4. Help needed for new Audi S3 8L owner.
    By Mr.G in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2008, 19:46
  5. Advice needed for new owner Plz S3????
    By ollyste in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2005, 19:17
