Friday,10,February,2012,13:00:50:36838
VCDS Version: Release 10.6.2
Data version: 20101123
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8P44A07****
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 BC
Component: SIMOS71 1.6l 2VG 5483
Revision: 00000003 Serial number: AUX7Z0C8F*****
Coding: 0000075
Shop #: WSC 06435 000 00000
VCID: 61C2B900871*****
9 Faults Found:
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 -- 009 -- Open or Short to Ground - Intermittent
Freeze Frame:
RPM: 0 /min
Temperature: 7.5°C
Temperature: 7.5°C
Speed: 0.0 km/h
RPM: 0 /min
Temperature: 7.5°C
Temperature: 7.5°C
Speed: 0.0 km/h
17979 - Left Engine Mount Solenoid Valve (N144): Short to Plus
P1571 -- 008 -- Implausible Signal
Freeze Frame:
RPM: 0 /min
Temperature: 7.5°C
Voltage: 11.53 V
Bin. Bits: 00000001
RPM: 0 /min
Temperature: 7.5°C
Voltage: 12.04 V
Bin. Bits: 00000001
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 -- 009 -- Open or Short to Ground - Intermittent
Freeze Frame:
RPM: 0 /min
Temperature: 7.5°C
Load: 8.6 %
16788 - EGR System: Range / Performance
P0404 -- 008 -- Implausible Signal - Intermittent
Freeze Frame:
RPM: 0 /min
Voltage: 11.12 V
Load: 0.0 %
Load: 0.0 %
RPM: 0 /min
Voltage: 0.00 V
Load: 0.0 %
Load: 0.0 %
17966 - Throttle Actuator (G186): Electrical Malfunction
P1558 -- 006 -- Short to Plus - Intermittent
Freeze Frame:
RPM: 0 /min
Bin. Bits: 00000001
Load: 100.0 %
Load: 0.0 %
RPM: 0 /min
Bin. Bits: 00000001
Load: 100.0 %
Load: 0.0 %
17585 - Bank2: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1177 -- 007 -- Short to Ground - Intermittent
Freeze Frame:
RPM: 0 /min
Bin. Bits: 00000001
Load: 100.0 %
Load: 0.0 %
RPM: 0 /min
Bin. Bits: 00000001
Load: 100.0 %
Load: 0.0 %
17578 - Mass Air Flow Sensor 2 (G246): Supply Voltage
P1170 -- 007 -- Short to Ground - Intermittent
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Absolute Pres.: 1005.5 mbar
Lambda: -1.0 %
RPM: 0 /min
Absolute Pres.: 1026.8 mbar
Lambda: 1.0 %
16506 - Throttle Position Sensor (G69): Signal too Low
P0122 -- 009 -- Open or Short to Ground - MIL ON
Freeze Frame:
Temperature: 4.5°C
Temperature: -40.5°C
Temperature: 4.5°C
RPM: 0 /min
P1639 -- 007 -- Short to Ground - Intermittent
Freeze Frame:
RPM: 0 /min
Voltage: 11.73 V
Load: 14.5 %
Load: 0.0 %
Readiness: 1110 1101
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No: 09G 927 750 B
Component: AQ 250 6F 0436
Coding: 0000008
VCID: 30640C449C7*****
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 -- No Signal/Communication - Intermittent - MIL ON
01315 - Transmission Control Module
013 -- Check DTC Memory - Intermittent - MIL ON
01693 - Valve for Throttle (N211)
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0051846
VCID: 336E03486D6*****
10 Faults Found:
00810 - Sensor 1/2 for Brake Pressure
005 -- No or Incorrect Basic Setting / Adaptation - Intermittent
00779 - Outside Air Temp Sensor (G17)
01436 - Brake Fluid Level too Low
01048 - Diesel Electronic Warning Light (K104)
00488 - Right Rear Outside Door Handle Central Locking Button (E372)
00783 - Positioning Motor; Left Rear (V78)
014 -- Defective - Intermittent
01329 - Convenience System Data Bus in Emergency Mode
01320 - Control Module for Climatronic (J255)
00674 - Release Brake Pedal
002 -- Lower Limit Exceeded - Intermittent
00286 - ABS Inlet/Outlet Valve; Rear Left (N139)
012 -- Electrical Fault in Circuit
