Volks AutosMonster Motorsport
Results 1 to 7 of 7
    tyrrelll's Avatar
    Lukey.T
    Mar 2009
    Leicester
    227
    Inside Tyre Wear?
    So today I took my wheels off for a good clean and i've noticed that the rear tyres have worn quite badly on the inside edge. The fronts seem to be fine. They are just budget tyres and they must of covered around 2k.. What would cause this? Is it simply that my tracking is out or could it be because i'm running a slight stretch of 225/35/19s or could it be anything to do with having my car lowered?
    Any advice appreciated before I fork out for new tyres, Thanks!
    WANTED - 8P Front Bumper 2005 onwards
    Jun 2010
    Coventry/Warwickshire
    2,074
    Its due to lowering .Get the car four wheel realigned asap
    tyrrelll's Avatar
    Lukey.T
    Mar 2009
    Leicester
    227
    Right okay thanks for the fast reply! I'll take a trip to the tyre fitter tomorrow then
    Jun 2010
    2,074
    You might save your tyres if you do
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Steve's on one tonight
    Oct 2010
    Bedfordshire
    58
    Quote Originally Posted by tyrrelll View Post
    If you have it lowered then it may be worth going for a full 4 wheel alignment which checks camber etc rather than just toe in/out. In my experience the car will improve with a proper set up anyway.
    Matt.
    A3 SB BE 170 TDI Quattro- Phantom Black
    If women can multi-task why can't they approach a roundabout and look right at the same time?
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Get the tyres swapped over and run them with the wear on the outer edges to increase their life
  1. Hi all i have a MAYOR issue with inside tyre wear...Need help URGENTLY..
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th September 2011, 18:37
  2. 2nd Service, Rear tyre, inside excessive wear
    By giblets46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2008, 10:50
  3. Inside tyre wear on -40mm lowered C5 A6
    By evomaster3000 in forum Handling
    Last Post: 26th March 2007, 16:48
  4. Help - Serious wear on the inside edges of front tyres.
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2006, 15:36
  5. MOVED: TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum General Chat
    Last Post: 28th March 2003, 12:18
