AH FabricationsVolks Autos
Page 3 of 3 FirstFirst 123
Results 81 to 93 of 93
Like Tree4Likes
Thread: A3 2.0TDI low poor sh*t MPG.. driving me crazy some 1help!!
  1. #81
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Sadly the Audi engines are not as efficient as the BMW engines. quattro also results in a substantial reduction in MPG.
    The later engines are not as economical as the earlier engines. The reason is the stricter emission standards. We;ve gone from Euro3 to Euro4 to Euro5 standard engines in the last few years. We all know about DPF's - these are 100% required to meet Euro5 standards. They also increase back pressure in the exhaust which reduced the pressure across the turbine which costs power and economy.
    The other requirement is the reduction in NOX production. To achieve the highest thermal efficiency, i.e. power and economy, the diesel needs to be injected at a specific point in the engine cycle. This point generates the highest cylinder pressure and the hottest most efficient burn. Unfortunately, this point also produces more pollutants in terms of Nitrogen oxides. Later cars are calibrated with retarded ignition timing - specifically in the mid range, in order to meet emission requirements. With a careful remap you have the option of optimising this timing and bringing back your lost economy.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  3. #82
    Jan 2012
    81
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    This is sad really, I thought the engine in my car was just a little more refined than my old golf. I wanted to keep away from post 2008 cars (obviously more expensive) but more costly to maintain when it's out of warranty.
    I'll look for a remap in a few months, although I'm not after total power increase - however maybe bring the power curve down a bit, but it would be nice to be more economical too!
    A3 3door S-Line 2006 TDI 140 (BKD engine code)
  4. #83
    Mar 2012
    21
    I bought an a3 bkd for the economy as have a long commute at present & travel on average about 350 miles a week and have done 9000 miles in my a3 since mid October. And the best I've managed is 520 miles to a tank and the worse was 460 when the weather was colder, the car is A1 condition and runs perfectly. Most of the time I drive very carefully as Im spending £300 a month on fuel.
    To be honest the economy isnt very impresseive considering I was doing the same commute in my Mk2 golf gti and that was managing 450 to tank on a regular basis and that was 21 years old, petrol & didn't depreciate & have mega repair bills!
  5. #84
    Mar 2012
    21
    Oh & my is DIS 6 mpg out so wouldn't bother reading into that to much until you've backed it up with maths.
    I reset mine when I bought the car, it now says 48.1 for the long term average over the last 9000 miles & I've logged every fill I've made and worked it out (as im sad) & its actually doing 42.3 mpg
  6. #85
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Just to save me deciphering the manual, which reading gives you the total average on the DIS? THe one that shwos you all the info on one screen only shows a Trip Average... which is very wrong.
  7. #86
    Jan 2012
    81
    The DIS shows the instant mpg, the mpg with the "o" with a cross though it shows the trip mpg (this is all in the "1" cycle). If you switch to "2" cycle it shows the same, but the mpg is since the last reset.
    Quote Originally Posted by daddycool View Post
    Hmm, very similar to mine then.
  8. #87
    Mar 2012
    Southampton
    436
    Thanks I found it. Mine says 47.7 mpg, my calculated brim to brim is actually 43.28 as I said above. So a 6 mpg over-read seems about average on these cars.
    Interestingly, my 318d was practically spot on to the calculated figures.
  9. #88
    Mar 2012
    21
    Mine is DSG which is offers slight condolence to myself when Im back at the petrol station!!!
  10. #89
    Mar 2012
    Southampton
    436
    Another fillup today Calculated mileage 45.51 up from 43.21 last time. Each time I fill up I gain another couple of miles per gallon lol.
  11. #90
    Aug 2003
    292
    I tried a fuel treatment on the last full tank and still only got 370 miles brimful to brimful.
    he worrying thing is that this tankful had a fair few of motorway trips rather than all the short heavy traffic trips of the previous tanks.
    It's a 07 2.0TDI 170 DSG sportback with 40k miles(2k miles since last full service)
    The dpf light came on once and I had to stop so I'm thinking was the regeneration stopped?
    It's done a regeneration since where I stayed on the motorway until the light went out.
    I have VCDS so I could force another regen
    has anyone any other advice as to what I could check?
    cheers
  12. #91
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Quote Originally Posted by paultaylor View Post
    cheers
    Got exactly the same issue as mine with pretty much the same driving & MPG, I changed the fuel filter as it was blocked (despite only being done 3k miles previously) & the MPG is creeping back up again. I'm also looking into the torsion value (VCDS>Engine>Measuring Blocks>004 - 4th box) as after looking into this it seems that even with it being a smidge out can lose 3-4MPG.
  13. #92
    Jan 2012
    81
    I just got 45.3mpg - which I think is ok. That's 510miles out of a tank (51.18litres back to brim full).
  14. #93
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    Quote Originally Posted by Jack_tdi View Post
    i was getting 400 to a tank every time in my 2.0 tdi 140 quattro i bought some redex fuel system cleaner just the little bottle from halfords (£2.50) and now my dis sys iv got 380 miles left nd iv done 110 may be a losd of **** but ill get back to you when iv used the full tank
    Actually got 450I but then 420 on my next tank so slighty better but it might just be my driving changing
  1. Getting poor MPG
    By Nutkin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2011, 18:42
  2. Poor MPG
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th March 2010, 14:27
  3. Poor driving - again !!
    By richs2891 in forum Rants & Raves
    Last Post: 20th January 2009, 20:06
  4. Poor MPG
    By SteveTDCi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2009, 18:10
  5. HELP!! Alarm driving me crazy!!!
    By mikeA2B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2004, 19:14
Tags for this Thread
