Have a 05 a3 tdi sport, it seems to not start perfectly after I've been playing my music , it works the first time I've started the car in the morning any ideas ?
Could be Sub related actually. What sub /amp are you running OP? If the amp and sub are drawing a lot of current it could be draining the battery, making it harder to start if you turn it off and re-start just after blasting your tunes. However this is only if your running a serious set up like 2500 Watt RMS atleast. Do the lights flicker with the basslines?
