AH FabricationsEM Tuning
    Sep 2011
    Newcastle Upon Tyne
    13
    MAP Sensor location??
    hi lads
    could anyone point me in the right direction to find the MAP sensor on a 05plate 2.0tdi quattro?
    regards
    Andrew
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    http://i1212.photobucket.com/albums/...5/35c35bb1.jpg
    if the photo works, this is the MAF sensor
    I might be corrected but I thought 2.0tdi only had a MAF sensor....
    Sep 2011
    Newcastle Upon Tyne
    13
    mmm... I've been told to change the map sensor, I've got the part ready to change but not sure where to look...
    cloughy's Avatar
    Sep 2011
    Berkshire
    515
    what's the part number you've got?
    Shiny S line Quattro
    Barnsley, South Yorkshire
    22
    Hi Mate the Map sensor is located below the oil filter housing on the turbo pipe you will have to remove the air intake top cover situated at front of the air filter housing, then you need to remove the ducting which is U shaped once this is removed you will be able to see the MAP sensor which is secured by two screws be careful removing the screws so that you dont drop them as they tend to roll under the engine on the engine undertray and are very hard to retrieve without removing the undertray. Hope this helps Cheers
  1. Cam sensor location BKD
    By robwilson69 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2013, 15:24
  2. egt sensor location on '03 S3
    By smest in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th November 2012, 12:12
  3. oil pressure sensor location
    By Shawny-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2011, 10:20
  4. Sensor and plug location
    By K7ERG in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2007, 15:33
  5. Location of temp sensor
    By imported_Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2005, 19:01
