JMB RetrofitsAH Fabrications
Page 3 of 3 FirstFirst 123
Results 81 to 95 of 95
Like Tree7Likes
Thread: Advice re 3.2 QS DSG
  1. #81
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    I'm going to ask about this recall when I phone and then just ask about the update at the same time. Doing this when I finish @12 today so I will let you know how I get on.
    Recall
    http://www.vosa.gov.uk/vosa/apps/rec...Text=Blank&tx=
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
  3. #82
    Oct 2011
    6
    Hi Ju.
    Does my car need an update?
    Address 01: Engine Labels: 022-906-032-BDB.lbl
    Part No SW: 022 906 032 GJ HW: Bas isX 3
    Component: MOTRONIC ME7.1.1G 6487
    Revision: 00000000 Serial number: AUX7Z0D7FNG0FM
    Coding: 0000178
    Shop #: WSC 06435 000 00000
    VCID: 59B2465C9002521
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 046 D HW: 02E 927 770 M
    Component: GSG DSG 0606
    Revision: 03149888 Serial number: 00000406300169
    Coding: 0000020
    VCID: 183403582B888B9
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Right phoned Glasgow Audi about the dsg recall from the vosa website and they don't know anything about it and when I questioned them about the software update they don't know anything about that to, even when I gave them the tpi number and the software disc part number so they want to get the car in for a £90/hour diagnostic check only to tell me there is no update as they have no idea.
    Waste of a call but what would you expect.
  5. #84
    Jul 2010
    561
    Quote Originally Posted by shariain View Post
    Recall
    Recall Details for AUDI - A3
    Not seen that before, need to check my chassis number.
  6. #85
    132
    Anyone tell me if this needs an update? Seems to not be on par with the content posted in this thread...
    Part No SW: 022 906 032 KC HW: 022 906 032 GP
    Component: A3-3.2-DQ-EU4 G 1282
    Revision: 1QH02--- Serial number: x
    Coding: 0000178
    Shop #:
    VCID: X
    Part No SW: 02E 300 011 CC HW: 02E 927 770 AE
    Component: GSG DSG 081 1401
    Revision: 04608010 Serial number: x
    Coding: 0000020
    Shop #: x
    VCID: x
    A3 3.2 S Line DSG
    A3 TDI S Line DSG Gone
    Update on A3/TT 3.2 V6 software update: See this post
  7. #86
    Sep 2009
    Trotters, Peckham
    539
    I suppose the update is free but will add that the dsg flash from HPA is one of the best mods for the 3.2 . Marcel is a genius at HPA and works closely with audi ag. Just my 0.02
  8. #87
    Mar 2008
    Woes continue!
    Over the last few months the car started to run really rough when coming to a stop. Symptoms were like a misfire with the car feeling like its juddering. Even when selcting N or P when stationary it didn't make a difference. 2 weeks ago it broke down and the RAC took it to a local garage who replaced the MAF sensor and spark plugs. Fault codes were also present for a number of the coil packs but I said I could get Audi to replace these due to an outstanding recall on my car. I booked it in with Walton Audi for today but yesterday it broke down with the same issues. Engine cuts out, try to start and it runs for a few seconds before cutting out again. Revs can be held by introducing the throttle but it then is virtually impossible to engage drive. RAC ended up towing me to Walton Audi yesterday and they've had it since. They informed me that my transmission is s-tronic not dsg and that the software update code is not applicable to my transmission. Is this correct? They replaced 3 coil packs but the engine still runs rough and cuts out after a few seconds of starting. I'm going out of my mind with worry as I've given them the nod to do further investigation works yet neither them noe myself know what the problem is. To confirm, my car is a 2004 A3 3.2 Quattro Sport s-tronic. My gear selector looks like this if it helps to confirm:
    If anyone has had similar problems and can give me some advice, I would be most grateful.
    Dave
    2004 A3 3.2 Quattro Sport DSG S-line
    2008 KTM 950 Supermoto
    1988 Honda CBR400RR Tri-Arm
  9. #88
    Apr 2012
    NL
    77
    Gee man, that sucks! I feel for you, but don't have any specific advice to give you, other than asking this question to clear things up:
    What gearbox software update did you get? The HPA DSG flash suggested above, or did it come with the Audi-update you requested them to carry out to remedy the 2000rpm issue?
    [edit: typo]
  10. #89
    Mar 2008
    Quote Originally Posted by Qua3ttro View Post
    [edit: typo]
    The software update hasn't been done yet so I'm assuming the car currently has whatever version it cam with as standard. I'm asking for update 2010289/3 to be carried out and waiting to hear from them.
  11. #90
    Mar 2008
    Update. Worst case, the car needs cam chains, cam chain tensioners and a whole load of other bits'n'bobs totalling £1532 which includes 5.5hrs of a techs time! Apparently the tenisioners come in a kit of parts which include new chains etc. Bu66er!
  12. #91
    Apr 2012
    NL
    77
    OUCH!
    But on the other hand: that's fairly cheap for a cam chain replacement!
  13. #92
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,203
    Sorry to hear that m8, that's another 3.2 with chain issues to add to the list. For chains though that's not a bad price, mine came to £3200
    Don't forget to get them to do the update foc while its in!
    S3 Sportback S-Tronic
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
  14. #93
    Mar 2008
    Update - Had the car back now for a week and it's been running great. Final bill was £1150.12 which covered cam chains, cam chain tensioners, crank shaft position sensors and a tonne of other bits which made for a full 2 page list. I was charged 3.5hrs for the entire 2 weeks they had the car which was decent of them as they ended up spending 19hrs in total trying to sort everthing out! Had an A5 Coupe 2ltr TFSI Sline Black Edition as a courtesy car which was nice! Now contemplating whether to keep the car or look for something else and chop it in!!! Problem is it's soooo nice to drive but I'm still paranoid every time I drive it when coming to a stop and expecting it to start playing up again! Maybe I'm just being silly and should enjoy the bloody thing!
  15. #94
    Sep 2009
    Surrey
    34
    Hi All
    Sorry for bringing this thread back up, but did not want to start a new thread.
    I have a 2005 05 Facelift 3.2 DSG, I did my research before buying and noted the 1800 RPM fluctuation and unable to hold he rev without feeling and hearing the missfire. Also the 5200 RPM to 5600 RPM flat spot / hesitation before pulling keenly to the red line. The car showed both of these on the test drive, but due to thinking it should be an easy fix, I took the chance did a deal and drove away.
    The following day the car was booked into the VW specialist, Volksautos, armed with TPI number and original details from this site, I asked them to install the software and look over the car.
    So copying from this site - I gave him these details:
    I have been made aware that there is a possible issue with the engine management system and that a software update for the ECU has been issued for this engine.
    The TPI number is 2010289/3 (it also worded gearbox judder poor acceleration when changing gears at high revs)
    The SVM code for the update is 8P01A005
    CD UPDATE DISC 4F0 906 961 N
    Unfortunately my car would not accept the software, the garage kept me up to date all the time, but the CD would not copy across the file, so they spoke to AUDI techincal who said as expected there is no update for this car and this update is manual only. They tried again this time with a new file from germany which came one day later, again no avail, it would not load it on to the car.
    Knowing this site had more info, I sent the other information in this thread, I won't cut and paste as it is on page 2 post 74 from the german site. Now for my model it does have reference points and notes Component -
    022,906,032 GJ: 8P DSG (BMJ): 8036
    The Specialist, who I do not doubt their ability, they come recommended and I have used them before on many occasions for previous VAG product, but they noted the CD number is the same for both updates, so they are keeping the car for a 3rd day while they wait for AUDI to see if they can find any new updates, they have sent them chassis numbers, all info from the ECU and anything else they need.
    So my question is, does anyone know 100% the correct Software / TPI / CD P/N for a 2005 05 Facelift 3.2 DSG? Any help is really appreciated
    Apr 2013
    Aberdeenshire
    594
    Quote Originally Posted by TDIDSG View Post
    Hi All
    I have a manual 3.2 I had a update but before the tech did it he said my ecu might not accept it but he wouldn't know until he tried otherwise I would have had to buy a new ecu for £800 .
