EM TuningBVR Automotive
Results 1 to 16 of 16
    May 2010
    274
    Pushing back rear caliper pistons?
    Anything special that I need to do for this?
    I had a quick go during the weekend past but I couldn't push back the piston at all using a G clamp. Didn't have time to fanny about with opening the bleed nipple etc.
    I've read elsewhere that because its the back and its also the E-Brake then it could be threaded?
    Just trying to save some pennies!
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,130
    G clamp !!!!!!!!! Jeeez. get the pison square and it should move back under the load of its own seal so slacken the bleed and try again. If not pump it a fraction to square it up then push back with your thumbs.
    May 2010
    274
    Question, engine on or off?
    Cause there is absolutely no chance that the above will happen if the engine is off!
    It was simple enough to do with my Corsa, though I don't know why is is so different?
    Khufu's Avatar
    West coast of Scotland
    5,692
    The rear pads need rotated in using a tool, there was a thread about it a few weeks back IIRC.
    The electronic brake system need the motors retracted using VCDS & then then pistons are pushed in. This system isnt fitted to the A3 - unless NHN has managed the retrofit & kept quiet LOL
    paddy's Avatar
    Feb 2008
    Surrey
    5,130
    Sorry i see you said back brakes so forget everything i said i will shut up now
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Halfords | Laser Left Brake Caliper Rewind Tool This is the tool you need but id get it from somewhere else as it will be a lot cheaper.
    May 2010
    274
    Reading the comments, some may need a right hand one too?
    or does the A3 only require a left hand tool?
    May 2010
    274
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    It works by rotating the piston as well as pushing it in. Not sure about what direction you need though but on my 8l a3 it was the one in the link. If you went to a motor factors they should be able to tell you which one you need. As well as the adaptor.
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    i screwed both mine clockwise with the wind in tool just take the cap off the brake fluid reservoir.
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    paddy's Avatar
    Feb 2008
    Surrey
    5,130
    Quote Originally Posted by a3dee View Post
    HE, HE, HE ,HE
    I see you have made no friends by your profile ? where do you live ? Got any buckets for sale ? PMSL
    Oh and i have been thanked 240 times because i try and help......I see you have been thanked once and i think that was me......lol
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,857
    the rear callipers need spun back using a tool
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Apr 2009
    Florida (previously Liverpool)
    655
    You can damage the threads by trying to use a G-clamp, so be very careful. -If you've bogged the threads up, you MIGHT have to replace the caliper... depending on how much force you used.
    I've seen a rear caliper on a MkIV buggered up using exactly that method... -it had to be replaced.
    Keith
    May 2010
    274
    Quote Originally Posted by VWAddict View Post
    Keith
    Balls. :|
    gary3306's Avatar
    Oct 2010
    Northumberland
    946
    Jonay, whereabouts are you mate. If you're close I could do it for you at my workshops (unless the car is already in bits of course ). I am in Northumberland.
    May 2010
    274
    Bit far I think, Aberdeenshire!
    Thanks a lot anyway, maybe if i need anything done in future! (void bushes? they need done!)
