Chris NottSky Insurance
Results 1 to 31 of 31
    Jul 2010
    561
    Attempted to fit LED numberplate lights - Not gone well
    Hi guys,
    Could anyone help, tried to fit a set of LED numberplate bulbs, put them in, fired up the car, got a bulb error on the DIS. Switched them around, still getting an error, put the old bulbs back in and I'm still getting the same.
    Do I have to clear the error to get them working? Or should it sort itself out if everything is seated properly?
    Thanks for any help!
    Oct 2008
    Telford
    2,488
    I assume you fitted resistors?
    B6 1.8T Avant s line gmbh
    Jul 2010
    561
    Went for the canbus designed bulbs here:
    eBay - The UK's Online Marketplace
    But even with the old bulbs in it's giving me an error. I'm pretty sure they're seated properly.
    Is it the fact that the error needs clearing that's stopping the normal bulbs working, or should that right itself?
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    It's buggered.
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Jul 2010
    561
    I'd managed to figure that out myself
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    sorry to hear that mate, hope you get it sorted
    Moved to the Darkside click below:
    Fossie
    Rhubarb Triangle
    3,968
    Apparently the fittings are a bad design.
    Check out all of this thread :-
    Number Plate Bulbs
    Jul 2010
    561
    I'll go have another fiddle.
    Does anyone know if one bulb will light up if the other is poorly seated or are they connected in series?
    Fossie
    Rhubarb Triangle
    3,968
    They are not connected in series - for a 12 volt bulb that would mean they only get 6 volts each.
    However, it may be that the ecu switches off power to both of them if one goes but I doubt it.
    That other thread describes the same problem and the fix.
    scottie123's Avatar
    Oct 2008
    1,888
    Correct
    They work independently to each other.
    Jul 2010
    561
    It's alive, it was exactly the same problem as linked too, had a go at siting the holders without a bulb in and could see the contact catching on the plastic.
    Working great now, the LEDs look great!
    Thank you all
    Oct 2008
    Telford
    2,488
    Anyone tried these? Expensive but look like an easy and bright alternative!
    AUDI Q7 A3 A6 A8 LED Canbus License Number Plate light on eBay (end time 27-Sep-10 13:24:28 BST)
    scottie123's Avatar
    Oct 2008
    1,888
    iirc some one fitted something similar a while ago.
    Tbh, they were to bright! looked like headlights on the back. LMFAO
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Quote Originally Posted by Lee_R View Post
    That's something similar to what i have, they are pretty bright yea but on the other hand they are plug and play with no errors
    There might be others that are not as bright but still direct replacement ?
    Jul 2010
    561
    The 3 led festoons are perfect tbh, not hugely brighter than the OEMs but much whiter, will get some pics. Cheap too, just a pain to fit.
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Quote Originally Posted by Minstadave View Post
    are these straight swop? no soldering of resistors?
    Jul 2010
    561
    Yup straight swap, they have the resistors mounted already on the PCB.
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Any links?
    Jul 2010
    561
    Quote Originally Posted by Smoothie View Post
    Any links?
    Link in post 3
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Link in post 3
    Sweet....error free i take it?
    PBA3's Avatar
    Don't hate, appreciate!
    May 2010
    So Paulo, Brasil
    35
    Guys ... on the 2009/2010 (mine is late 2009 build) NONE of the ebay that say ERROR FREE will work. I had to install a "canceller" before the lights into the harness. Racing Dash sent me the part because their lights also don't work with the newer A3's I can ask them for more details if you guys want, but if you contact them they will be happy to assist also. They're extremely helpful.
    oH snAp!
    xnox202's Avatar
    Apr 2010
    193
    Do you have a pic of this canceller? Would they sell just the canceller part? Or is it a part of their own LED set?
    2010, Matte White Spray/Coated - Audi A3 Sportback 2.0 TFSI DSG
    APR Stage 2+ RON 98 ECU Reflash | Eurojet 3" Turboback Exhaust | BSH (Stage 1+2 Intake/Pendulum Mount/Integrated Throttle Pipe/Boost Tap) | AWE Turbo Outlet Pipe | Neuspeed TSI Torque Arm Insert | Stock Intercooler | Vogtland 35mm | HID 6000k (Main D3S + Fogs H11) | LED @ Full Interior/License Plate | CF @ Side Mirror/B-Pillar/Interior
    PBA3's Avatar
    May 2010
    So Paulo, Brasil
    35
    It is separate. They sent it to me after I bought their license plate lights.
    oH snAp!
    xnox202's Avatar
    Apr 2010
    193
    I wonder if their canceller works with any other LED sets. Where can I buy this canceller?
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    what size are the front courtsey lights? (Non-map reading lights) I only have the one switch to operate 2 individual lights......
    MY 07 IMOLA S3 FOR SALE............
    http://www.autotrader.co.uk/classifi...98ba?logcode=p
    Aug 2008
    408
    i hope these lamps work ok for ya bud, several of mine have failed already and the supplier is terrible to deal with, now in paypals hands
    cal
  28. #27
    PBA3's Avatar
    May 2010
    So Paulo, Brasil
    35
    Yes the racing dash canceller works with any LED bulb. The racing dash license plate lights were WAY too bright, so I replaced them with a set of LEDs and no dash bulb error message for months now.
    Here is their website Racing Dash Enterprise Ltd. I spoke with Sherry at manager@rdash.com.tw
    oH snAp!
  29. #28
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Quote Originally Posted by bluequattro View Post
    Cal did the bulbs produce an error or just faulty bulbs?
  30. #29
    Aug 2008
    408
    Smoothie, i got an error first, which i cleared, however the
    Lamps started flickering, ive replaced them for standard
    And will never buy again from f1 autoparts or theyre other
    Ebay shop called easy driving
    Cal
  31. #30
    scottie123's Avatar
    Oct 2008
    1,888
    Quote Originally Posted by PBA3 View Post
    How does that work then? Surely they still look for current draw and kill supply if there is none. Unless they have made the tolerance of the amps smaller so less room for error when installing resistors to fool it.
    I suspect this cancelling box may have resistors in it
    Do you have any more info on this PBA3?
    05 SB SE BKD
    Build Thread
  32. #31
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Cal
    Thanks for that mate, i've got the LED's that came as the whole housing, they work perfect but a little bright for my liking! I thought these were the ones to go for with the resistor built in..
    Whats everyone else running?
