Badger5Sky Insurance
Results 1 to 30 of 30
Like Tree7Likes
  • 1 Post By Siwills1980
  • 1 Post By Sandra
  • 1 Post By Sandra
  • 1 Post By S3Alex
  • 2 Post By kris@forge
Thread: dump valve for audi s3 57
    Jun 2010
    which one to get and are they any good?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    You've got a choice of the current OEM diverter valve(strictly speaking it's not a dump valve) which is not too far away in design from the Forge,and of course the Forge DV itself,which most of us use.
    Forge Motorsport | Alloy Fabrication
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    lifetime warranty as well
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    Neither the OE or Forge DVs are Dump Valves as you may recognise from other turbo applications and neither provide any aural or performance enhancement. Unless your car is mapped you will not see any benefit (which is reliability) from changing your Diverter Valve.
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    I have a box of these valves from standard cars in varying states of failure , with this being one of the worst
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,047
    Isnt there a later version of the OEM DV for the 20TFSI which addresses the diaphragm failure?
    cheers
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    Quote Originally Posted by Forge View Post
    What's you point? If he is running a standard car the OE DV is up to the task.
    Edit: I should say that mine (mapped) was running this for the last 14k miles and is as good as new, so lets not go over the top here and scare the chap into buying something he may never need.
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    Quote Originally Posted by PaulAr View Post
    cheers
    Paul
    Yes mate, the Rev D as seen here. Linky
    Looks like that picture of the failed DV gets round a bit too.
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    I am saying that we have seen the valves failed on the standard un chipped cars as well , granted not as often but it still happens , the revised valve is more robust BUT we still have the valves fail.. its usually a break down in the top plastic part , it breaks away ...
    Jun 2010
    so if i was to fit one to my s3 would i get the blow of noise?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Quote Originally Posted by GilesS31986 View Post
    Not unless you fit one of these things....
    But it begs the question....why.....all it does is make a noise.
    It doesn't add anything to the car's performance.
    You're getting a bit tied up between diverter valves,which the VAG cars use,and dump valves,which some other cars use.
    On a system which measures air flow,such as the VAG system,the air flow is measured by the MAF sensor in the inlet tract prior to the turbo and intercooler.
    If on closing the throttle,you then dump that air to atmosphere via a dump valve,the ECU's air flow calculations will be wrong,as it assumes that measured air flow is still correct.
    The VAG system thus DIVERTS that flow back into the intake,after the MAF sensor.
    Oct 2008
    888
    Good to see you took note Alex
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    I'd go for the Revision D. It's a lot cheaper (about 45 from Audi IIRC) and I haven't heard of any problems with them. My original one was just fine when I took it off at about 24k BTW.
    If you want noise you need an Evoms/ITG intake
    8P2 S3
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    The information is correct the Forge FMDV14T is a blow off spacer it fits between the solenoid and your turbo , it will give to the blow off pssshhht sound between gear changes , but will do ntohing to improve your performance or engine efficiency in any way , neither will harm your engine in any way ...if you like the sound it is a cheap and effective way of achieving it , easliy removed as well .
    The Forge diverter valve replacement will work with the spacer as well ..
    If you fancy an intake the Forge Twintake gave 18 BHP on a stanadard car !!!
    many happy customers on AS with them
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Fellas - quick question. When did the revision D diverter valve come out? I've got a March 07 S3 and my dealer says I've got the latest version of the valve. I thought the revision D came out later than that. Who's right?
    I could look, but the car's in for the 4th day for a simple warranty fix gone sideways. Again.
    Oct 2008
    888
    You are, mines is a 08 and it was the older type
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    The revision D valve came out late 2007 in the Seat range. ETKA is no help as the new part number overrides the old part number so cant see an introduction date on the S3.
    Shane.'s Avatar
    509
    Well this thread jinxed my car, was reading it last night went to shops and then it happened to me got code checked today and all things point to the DV so will be getting a forge one fitted next week sometime
    STUFF FOR SALE: DLS R6 Midbass drivers, MFSW 3 spoke and Pioneer P88RS II
    STUFF FOR SWAPS:
    3 door A3 8P custom doorbuilds
    please contact for more info
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    Cheers for the info dc & mr Forge. I'll get a revision D one ordered up...
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Mine is 08 too BTW, I think the revision D came out late 2008.
    8P2 S3
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Quote Originally Posted by dc240969 View Post
    Ehhhh?
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    happy to help
    May 2013
    Wrexham
    I fitted the forge fmdv14t and the car did not run right with it on . The car would be hunting for revs ie at traffic lights or roundabouts and most ov the time cut out ! . Is this a fault or something you have heard ov before
    Sandra likes this.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,343
    Quote Originally Posted by Siwills1980 View Post
    Hi welcome to audi-sport.net. Enjoy the forum. x
    Siwills1980 likes this.
    May 2013
    Wrexham
    Thanks x
    Sandra likes this.
  28. #27
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,343
    Thanks x
    For local meets, click the link below. x
    Smaller (Local) Events
  29. #28
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Best to call Forge direct.
    Excellent and fast customer service.
  30. #29
    kris@forge's Avatar
    Aug 2010
    Gloucester
    42
    Please give me a call on 01452 380999 and ask for Kris.
    ive not heard of this problem but ill try my best to sort it for you.
    S3Alex and Siwills1980 like this.
  31. #30
    May 2013
    Wrexham
    Only just seen the message krises will phone u sometime tomorrow cheers :-)
