EM TuningSky Insurance
Results 1 to 7 of 7
    coopsS3's Avatar
    Woosh Woosh Wah...
    May 2010
    Manchester
    32
    Weekend drive comes to a stop!!!! (0) <----- HELP
    Hi well my cars just had its near side bearing done, its all waxed n shiny ready for the weekend drive 30miles into it A WARNING LIGHT!!! Not happy
    So im asking for your help again guys...... (0) <----- the sybmol in amber! is in the book but not with an empty circle. Is this simply because the system cant pinpoint a problem so i have a priority 2 problem sumwhere in my ABS/ Breaking system?? i was on the bypass and it came on as i went round the roundabout at about 40, the wheel did clip the drain could this have caused the problem! hope u can help thanks :D
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Isn't (0) a brake pad low warning.
    Probably just the wire is damaged if someones had the hub apart.
    Edit - Images
    coopsS3's Avatar
    Woosh Woosh Wah...
    May 2010
    Manchester
    32
    Brilliant thanks mate just checked my rear pads n there a little low! was worrying was gonna be summit expensive haha thanks again
    Love this website all my troubles get sorted in minutes :D
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Rear pads don't have sensors.
    Be the fronts but like I said the wires are pretty weak so may well have just snapped which will bring up the warning.
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Ye it is the brake pad wear sensor. Dont worry though as you have about another 1000 miles before they need changing.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,639
    As already mentioned, it wont be your back brakes, they dont show up on your dash they will be the front ones that need changing, either that or the wire has snapped.
    Chugger
    North Devon
    2,716
    I get warning lights all the time, nothing to panic about.
    You only have a sensor on the passenger side front.
    57 A3 2.0 TDI Sportback (140)
